351c fuel pump |
Author | ||
michmusman ![]() New Member ![]() Joined: 09-September-2021 Location: Georgia Status: Offline Points: 10 |
![]() ![]() ![]() ![]() ![]() Posted: 29-October-2021 at 1:12PM |
I am trying to replace the fuel system on a 72 Gran Torino and I thought I saved the easiest part for last. All I need to do now is to replace the mechanical fuel pump but I am having trouble getting a wrench on the upper fuel pump bolt. Do I have to lift the air-conditioning compressor to get at it or is there a trick I cannot figure out? Do I have to lift more than the air conditioning compressor?
Any tips greatly appreciated. thanks, Steve
Steve
72 Gran Torino former 71 Torino |
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 5941 |
i haven't dealt with an A/C'd Clevo in decades and i'm having trouble seeing it from here LOL
have you had a go from underneath yet? |
72 RS 351 ![]() Senior Member ![]() ![]() Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 2653 |
I would bet the FP bolts are like getting at water thermostat housing bolts on 302's. I know I changed the fuel pump on my 351C-2V when I had it in high school, the AC compressor doesn't have to be moved. Find the right socket and extensions for a ratchet. I love a 1/4" drive ratchet with extension and a 1/2" swivel socket, for the distributor hold down, and the 302 thermostat bolts. It likely will take that kind of tool combination to get at those FP bolts.
Thanks, Don!
I am able to get a crow's foot wrench on it and with a swivel extension, I think I will be able to get the job done. I am going to make a trip to the store to see if I can just find a swivel socket to fit over the bolt and extend around the FP housing for a bit easier time of it. Steve
Steve
Yes, some things require special tools or extra time for. I acquired my Snap-On 1/2" swivel socket over 302 years ago, then just for the distributor. It was about $15 off of the Snap-On truck, and worth it many times since then. I have most swivel sockets now, Craftsman sets I got many years back. Keep at it and slowly figure out what tools are worth buying for a one time use, and others that are best to borrow or rent.
BadHabit351 ![]() Senior Member ![]() Joined: 21-June-2013 Location: United States Status: Offline Points: 217 |
302 years ago...dang, dude...just how old ARE you?
1973/72 Gran Torino Sport
1971 Torino GT convertilble 2013 Ford Fusion 2004 Ford SuperDuty 2013 Mustang GT |
Funny, I didn't catch that in editing. I typed "30", and then wanted to say "over ...", so went back and changed the "0" to a "2", but obviously didn't delete the "0." I bought that socket before 1988, when I was working at several dealers where the tool trucks visited every week.
Bueller ![]() Member ![]() Joined: 20-November-2020 Location: Kansas Status: Offline Points: 77 |
I just replaced mine a couple of months ago, and I had to take the power steering pump loose to get to it without special tools. It was a breeze once I did that (the morning before our big car show no less!) 351C with AC
Frank
Inkara1 ![]() Member ![]() ![]() Joined: 17-November-2021 Location: Ridgecrest, CA Status: Offline Points: 193 |
I replaced mine a week or two ago. I used a normal 1/2 inch wrench for the bottom bolt, and a socket with one of these wrenches for the top. I didn't have to move the power steering pump or anything, since the handle is short enough and can change its angle.
AUS GTS ![]() Senior Member ![]() ![]() Joined: 26-July-2021 Location: Australia Status: Offline Points: 380 |
Can anyone tell me why my new fuel pump came
with 2 gaskets??
Al
Thinking cause some engines that use this same pump have a spacer??
Removed the old one... bolts were finger tight & x2 gaskets fell off with it! lol... bonus 3rd gasket still on mounting pad took an hour to get off & clean up....ffs! Figure i'll use 1 with some gasket sealer !
Al
handsofstone ![]() Senior Member ![]() Joined: 13-April-2018 Location: Northeast Status: Offline Points: 3920 |
I think mine was cleaned and the new pump installed without a sealer. There is no pressure on the gasket, just oil from the timing chain. I am willing to bet it is there in the event you break one. Then you won't get stuck needing a ride to an auto parts store.
Edited by handsofstone - 16-March-2023 at 4:25PM |
Cheers for that fella!
Al
All done, top bolt was a pain but managed it from the top, without moving the power steering pump, just using a standard 1/2" spanner.... 1/10th of a turn at a time. lol & yes the 2nd gasket is for other engines with a spacer!
Al
Want to swap out the hard line from the pump.... is that thread 1/4" NPT ??
Al
dan0R30 ![]() Senior Member ![]() ![]() Joined: 30-June-2020 Location: USA Status: Offline Points: 617 |
Should be 5/16. I used this on my Carter pump to run a 3/8 hose to my carb:
Edelmann 822560 Brass 5/16" Inverted Flare X 3/8" Hose 90 Degree Elbow Fitting ![]() |
Dan
1970 Ford Torino hardtop - 351C 4V - FMX - 9" 3.00 |
Thanks Dan, wasn't aware or the correct terminology either!
Al
5/16" is the tubing size but threaded flare connections don't use NPT. it just is what it is for the 'tube nut' for the correct diameter tube for the outlet port on the pump. it's a straight thread so the NPT taper doesn't snug up before the flare crushes. if the fuel pump has a threaded inlet port w/o a flare then that will be tapered NPT unless it's a high-end pump, then all bets are off as it could be machined for a Straight Threaded O ring (STO) connection
Al
Have ordered that same one from the U.S. , as its "cheaper" than the local speed shops.
Al
