351C Head information from Rockatansky |
Post Reply
| Author | |
torkair
Joined: 01-May-2010 Location: Tucson, Az Status: Offline Points: 430 |
Quote Reply
Topic: 351C Head information from RockatanskyPosted: 02-January-2012 at 5:07PM |
Boss
heads were only made for the1971 production year and are pretty rare. they have a different volume chamber than the rest of the closed chamber 4V's. D1AE-GA is the only cast code for the correct Boss chamber volume, and carries Ford part number D1ZZ-6049-B but not all -GA castings were machined into Boss adjustable hardware heads there
was an open chamber brother to the 71 Boss head used on the 1972 HO
engine, it also has adjustable rockers with screw in studs and guide plates like the Boss. both used single groove valve locks instead of the multi groove that the rest of the Clevelands got some
say that Boss replacement heads could be bought over the parst counter
for many years after the 1971 model year production, and that there was a production run to supply the parts counter with Boss heads that has a later date code... could be? the 2nd pic on this link http://351cleveland.wetpaint.com/page/4V+Cylinder+Head+Spreadsheet shows
where to find the casting date code for the heads. then using the chart
'sorted by date' you can figure out where your heads stand in the production timeline and whether they're open or closed chamber, unless they fall between Sarah's 1F2 and Steve's 1M23 dates Boss & HO rockers, notice no locking tab that fits into the pedestal ![]() point is lots of guys will call any 4V Cleveland a Boss head myself included until i learned exacty what made a Boss head Boss when you pop a valve cover let's see what it is! wouldn't you trade 80 #'s or whatever it is for several hundred HP? the first time you hammer down a 4V you'll think the 302's are good for golf carts Edited by GranTorinoSport - 03-January-2012 at 8:46AM |
Guests
Guest
Quote Reply
Posted: 03-January-2012 at 8:35AM |
it's ashame but the photos were lost with copying the info to this thread.
I was affraid that might happen but didn't want to lose the info. above all together. Edited by 72 GTS 429 - 03-January-2012 at 9:03AM |
GranTorinoSport
Admin of "The Org" Joined: 20-May-2003 Location: Seattle Status: Offline Points: 2290 |
Quote Reply
Posted: 03-January-2012 at 8:48AM |
Done. I deleted my post and added the picture. The picture was not gone, but that method of displaying photos seems to end up not showing them (my mac for example). I just downloaded it on a PC and then added it up here traditionally.
Webmaster |
Guests
Guest
Quote Reply
Posted: 03-January-2012 at 9:03AM |
that's great Scott as the info. discribed a difference in the rockers but the photo wasn't there to look at and now it is
Post Reply
| Tweet |
