  New Posts New Posts RSS Feed - 351c oiling up?
351c oiling up?
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: 351c oiling up?
    Posted: 23-September-2022 at 3:49AM
I am doing some basic maintenance on the 351cj.
I have oil primed the engine, but oil is only coming out to 5 valves.
I have spun the crank too. I am priming/spinning counterclockwise by hand. I can feel some resistance/pressure…..
Is hand priming enough to oil up?
Edited by Anderslober - 23-September-2022 at 8:10AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 23-September-2022 at 4:13AM
You should probably use a strong drill to turn the oil pump at the slowest speed, that will tell if all of the rockers are seeing oil.
Have you removed the rockers or pushrods yet? I'd take them out and be careful to keep them in the original order. Don't mix up the pushrods or the rocker components. With them out you can inspect the tips of the pushrods, be sure they are clean through, as well as the rocker surfaces, check for wear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 23-September-2022 at 4:45AM
I did not take the pushrods out or anything. I will try with a drill tomorrow….
