  New Posts New Posts RSS Feed - 351c points gap
351c points gap
vess3xblack72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vess3xblack72 Quote  Post ReplyReply Direct Link To This Post Topic: 351c points gap
    Posted: 05-July-2013 at 11:23AM
Anyone know what the points gap is for a clevland. Interweb is unclear. .017, .020????
Thanks,
Benjie
torinojon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2013 at 5:59PM
i gap my points at .021 when i do them...
Robbdtme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbdtme Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2013 at 8:42PM
The gap changes timing. Start with .020 then put a dwell meter on it.  adjust until 28-32  Dwell. Set timing then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2013 at 3:13AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote vess3xblack72 Quote  Post ReplyReply Direct Link To This Post Posted: 08-July-2013 at 3:14AM
Thanks. I Knew About The Conversion Kits . Just Trying To Get It Running Now.I'm Thinking The Fuel Pump Is Bad It Will Idle Fine But Sputters With Throttle In Any Amount. Wouldn't Even Start Before I Changed The Points And Condenser.
Thanks,
Benjie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbdtme Quote  Post ReplyReply Direct Link To This Post Posted: 08-July-2013 at 5:50AM
Accell pump and power valve diaphrams in the carb like to get hard and brittle. Might be your sputter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vess3xblack72 Quote  Post ReplyReply Direct Link To This Post Posted: 08-July-2013 at 5:52AM
Thanks. I'll Check That Out Too.
Thanks,
Benjie
