351C Timing |
Page <12 |
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5449 |
What do you mean in your third point? Are you saying that George is conservative or too aggressive on the DCR because he does sports car engines? I am not really sure what you mean. My engine has mid 7s for DCR and I wouldn't want too much higher than that, especially since 91 Octane is the best I can get. I agree with Rock, your DCR is too high. The way I see it is you have two viable options. First, replace the cam, which probably will move your power band, which is why I asked what gears you are running. I suggested asking George for a cam grind, but I didn't know his health was down. It's too bad because he did help me out when I was doing my build. In the end I used a custom grind designed by Tim Meyer. Second, reduce the compression, either with new pistons, or by increasing the combustion chamber size like Rock showed above. If you are pulling the intake, pulling the heads to work on the chambers might be not too bad of a job, but I can't say I'd want to go at the combustion chambers with a die grinder, I'd worry I'd mess something up. Maybe you are up for that kind of work or there is some in your area that can do it? Check you PMs, I will send you something else that might help you out.
Edited by 72FordGTS - 08-November-2022 at 9:57AM |
handsofstone ![]() Senior Member ![]() Joined: 13-April-2018 Location: Northeast Status: Offline Points: 3828 |
Chuck,
Billy Ray's Haberdashery and Tim Halstead on Facebook might have some tips as well. Billy Ray does some nice work and videos on youtube as does Tim. Not sure where Billy is located but if he is nearby it may be worth it to have him tweek the chambers to lower your compression to work with your current setup.
lynchster ![]() Senior Member ![]() ![]() Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 2127 |
I wouldn't say he's concervative or agressive. The longer LSA's he prefers would seem to indicate his tuning preferences. Not a bad thing, a preference. Figuring that the Boss 351 was running a similar compression ratio I'm not really considering dished pistols or redoing the heads. Since the block is studded that's pulling the engine and it's taken 17 years to get this together. According to Pense the cast heads can support a dcr of 8.0 which seem to indicate cylinder pressures in 160 range. I've seen other Cleveland builds in the 180 range. Mine is right there and it would indicate to me that there are too many compromises involved in that range. I figure if Ford can offer a 10.6:1 Cleveland with a dcr in the 7.5 - 7.7 range in a production car I should be able to come up with a roller cam in the 7.5 - 8.0 range without killing it. Howard's offers an off the shelf cam with an IVC of 69 that would theoretically put the cylinder psi at 162-ish. The centerline is 106 and the exhaust lift is .611. I'm considering a design tha staggers the exhaust valve no higher than .600 and opening the lsa to 110 - 112.. I'm not sure how it works in practice but I think with a couple of tweaks I can get the PSI to 155-160 easily. The question being how does the altered cam timing effect the engine. |
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 5848 |
DCR's from 69* IVC Static compression ratio of 10.4:1 Your dynamic compression ratio is 8.01:1 Your dynamic cranking pressure is 163.82 PSI Static compression ratio of 10.5:1 Your dynamic compression ratio is 8.08:1 Your dynamic cranking pressure is 165.69 PSI unfortunately you don't have any elevation to speak of to help out. i've been using flat sea level. bumping you up to 1000' makes a difference but IMO you should plan for the worst Static compression ratio of 10.4:1 Effective stroke is 2.61 inches Your dynamic compression ratio is 8.01:1 Your dynamic cranking pressure is 158.48 PSI Your effective compression ratio reflecting 1000' altitude, is 7.81 :1 Static compression ratio of 10.5:1 Your dynamic compression ratio is 8.08:1 Your dynamic cranking pressure is 160.34 PSI Your effective compression ratio reflecting 1000' altitude is 7.88 :1 |
Ok, now I understand what you mean about Pence's preferences. But even Rock said to keep the DCR at 8 or lower too. One thing you have to remember when looking at DCRs from engines like the BOSS 351 and the other high compression engines from this era is they used higher octane fuels then that we don't have readily available today. I liked Rock' recommendation of keeping DCR at 7.7-7.8 and from his math above the 69* IVC doesn't seem to do it. I sent you a Google Drop Box download. Not sure if you got it or it worked? It might help you with the cam selection.
Thanks Vince
Now I know where the slight differences in pressure are! I've been using 300 ft. I'm at 450 but surrounding areas dip to 300. Weird going in because I just pulled the altitude out my head for consistent numbers. I've made two phone calls this week and had rambling conversations with with a guy at Howard's. That cam at 112* LSA gets me to 71 IVC. My only concern there is the .611 lift on the exhaust side without the lifter bore sleeves.
72 RS 351 ![]() Senior Member ![]() ![]() Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 2449 |
If you pay for a custom cam, the extra $100 gets you control over everything. You set the limits as you want them, and they should easily design a cam to meet them. If you don't want it to open the valves more than .600, you tell them that. My refresh I'm hoping to use OEM type rockers, which have a general limit of .550", if I can run them to 6000+ rpm or a little more, that's a limit I will set for the cam. Tell them what you require, it's their job to design it to work optimally within those. If you are having pre-designed cams suggested to you, then those are not going to be the best possible for your engine and vehicle.
I've been having fun with that calculator.
this is Brent Lykins cam page, i'm sure he can cobble a cam for you to make it all happen. just a heads-up Brent and George didn't quite see eye to eye. give him a call & rake it over the coals, if Brent's not your cup of tea we can pull a recipe from George's web page. i know there's a hydro roller or 2 in there somewhere and get it ground by Bullet. i'll start looking if i get a chance
a couple hydraulic rollers from George's cook book 69.5* IVC hyd-roller |
Thanks Rock!
Interesting experiment but I have no idea of the math behind it.
In the dyno2000 program I took the flat tappet Boss351 Cam and flipped the same specs to a roller cam. That alone netted a 45 Hp / 36 TQ increase. I assume it's just in the projected cam lob profiles. ?
I think you are correct about the program making the assumption on the ramp rates of the cam lobes. The hp figures in the program aren't always the most accurate but what it is really useful for is comparing changes from one cam, head or other changes to another and the affect on the power curve etc. I did some stock do some stock engines with the program and got pretty close to the advertised figures (gross SAE numbers).
I did that with the Boss351 cam. Now I'm experimenting......
I picked 2 cams so far. One from George and one of the Howard's off the shelf cams 235245-12.
LIFT DUR LCA ICL PSI DCR George's cam 70* IVC .544/.544 .278/.286 114 111 160 7.96 Howard's 67*IVC .576/.600 .278/.282 112 108 166 8.14 230245-12 Howard's -3 70*IVC .576/.600 .278/.282 112 111 160 7.96 230245-12 George's cam 396HP @ 6K 411TQ @ 4.5K Howard's -3 405HP @ 6K 410TQ @ 4.5K Howards -4 405HP @ 6K 408TQ @4.5K These following are my assumptions based on how I understand what I'm looking at. Please feel free to correct if so inclined. Georges cam is 3* advanced 114 LSA / 111 LCA 70* IVC Howard's 230245-12 is 4* advanced 112 LSA / 108 LCA 67* IVC I assume if I install the 230245-12 3* retarded 112 LSA/ 111 LCA 70* IVC If that's the case taking out the whole 4* advance 112LSA/ 112 LCA 71* IVC Basically losing 1-3 ft lbs of torque in a place I'd never miss it. The HP and TQ between Georges cam and a 3* retarded 230245-12 cam are just about identical until you get to 5500 and 6000 rpm where Georges cam falls of by 4HP/4TQ and 9HP/9TQ. Not very important picking one over the other in a street car. I find the lift differences and similar power curves somewhat confusing The previous numbers were based off the Dyno2000 program with a dual plane intake and HP manifolds (they are large compared to most) w/ full exhaust Large tube headers w/ full exhaust 453HP @ 6K 451TQ @ 4.5K Add Single Plane 490HP @ 6K 469TQ @ 5K Drop the exhaust 503HP @ 6K 480TQ @ 5K |
factor in chain stretch and i think you'll get that 3* you're looking for fairly quickly. me personally i'd target at least that 72* IVC figure i came up with, it'd be a pisser to go through it all and still be on the edge
Not too happy about it now but it is what it is. I'm just as concerned about going too soft as I am too hard. Disappointment is not what I'm looking for in a 17 year project.
How does it look if you retard the Howard's cam 6 degrees so it runs 2 degrees retarded? This timing set allows for +- 8 degrees at 2 degree increments: Can you post pics of the power curves?
Edited by 72FordGTS - 15-November-2022 at 6:55AM |
Didn't even think to check at 8*. 😮
I had re read your post. I'm likely going to just swap the camshaft but I'm having a lot of fun with the program. I retarded the cam 8* (in the program!). It flipped the cycles on the intake and exhaust. Likely more than obvious to someone who's studied camshafts. If I understand what I'm reading it would likely cause exhaust reversion. The intake closes at 68.3 but the exhaust is closing at 64.3. Most are closing in the mid to late 70's. It does mathematically look better in the program. As it sits 392HP @ 5500 / 426TQ at 4000 8* retard 407HP @ 6000 / 411TQ at 4000 and 4500 |
Apparently not the way normal people do..... This is one retarding my cam 8* versus the 235245-12 retarded 3*. Not much difference on paper but the latter has slightly better vol eff. The latter also has an exhaust cycle 14* longer Without dots is the cam I have -8* ![]() |
The retarding helps but it seems not enough. From the DCR calculator at 300' it shows: Static compression ratio of 10.4:1. Effective stroke is 2.84 inches. Your dynamic compression ratio is 8.12:1 . Your dynamic cranking pressure is 165.15 PSI. Your effective boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of PSI is 8.06 :1. V/P (Volume to Pressure Index) is 144 Interesting seeing the power curves don't change that much between the cams. What I actually wanted you to try was retarding the Howard's 230245-12 6 degrees instead of 3 degrees as you indicated above. I think that might get your DCR to a safer range and not affect the power curve too much. Runinng the Howard's 230245-12 at 3 degrees retarded seem to get the DCR close, so I thought 6 degrees might be right on the money. Maybe Rock will have a better idea.
Page <12 |
