  New Posts New Posts RSS Feed - 351C-4V Knocking, oil compression lost
r9b2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote r9b2 Quote  Post ReplyReply Direct Link To This Post Topic: 351C-4V Knocking, oil compression lost
    Posted: 03-November-2024 at 1:30PM
Went to take my car on a maiden voyage of sorts. It's an essentially new 351C, all new parts built from the ground up. Car developed a ticking (probably from the lifters), and that turned into a loud knocking noise at higher rpms. Losing oil, white smoke from exhaust, and oil compression went from being about 75 psi to under barely 40, at idle it's VERY low. There's definitely a problem with compression in the engine too -- the transmission isn't downshifting into first when the car comes to a stop.
When I started hearing the knocking, I immediately pulled over and got a tow truck. The car is extremely low on power, it could hardly move into the gas station I pulled into from a dead stop. I have no idea what happened, could someone point me in the right direction? Thanks in advance.
1975 Ford F150 300I6 4spd 4x4 Project
1973 Ford F100 429
1966 Ford Mustang I6
2025 Subaru Forester
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-November-2024 at 1:58PM
pull the plugs and run a cranking cylinder pressure test, drop the oil and cut the filter open
white smoke, watch out for water / coolant shooting out the plug holes
maybe pull the valve covers off and try to discern whether all the rockers are going full swing during the compression test
Edited by Rockatansky - 03-November-2024 at 2:04PM
Booyah45828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Booyah45828 Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2024 at 5:06AM
Drain the oil and see what you find. Hearing that you have knocking, low oil pressure, and low compression my gut tells me you've got bottom end damage. It sucks that this was just rebuilt.
r9b2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote r9b2 Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2025 at 4:40AM
Just a quick update on this since I forgot, the camshaft was toast (just after about 1-2 hours worth of run time). It was mostly the exhaust lifters that got cooked as well, which was causing the oil problem as well. Currently looking into a better camshaft, only problem is that all I know is that it was a Comp Cam; the guy who supplied the parts for me unfortunately passed away and never gave me a cam card.
1973 Ford F100 429
Post Options Post Options   Thanks (0) Thanks(0)   Quote Booyah45828 Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2025 at 7:03AM
Was it a custom or shelf cam? There's only so many shelf options from comp that you should be able to single it out pretty easily with some measurements. If it's custom that's altogether different, and the actual cam specs might never be found.
With such a short run time, are you going with a roller cam this next time? I'd suggest doing so if you weren't. With it running rough, you likely sent shrapnel throughout the engine, so this will probably need to be removed and rebuilt again.
