4 speed conversion |
Scott
Senior Member Joined: 31-January-2012 Location: Versailles,Ohio Status: Offline Points: 216 |
Posted: 29-August-2013 at 1:15PM |
For those of you that changed your floor shift car to a 4 speed car did you have to alter the hump any or the factory hole in the floor or does all of this work with the 4 speed?Console too?Thanks,Scott
papadeath
Senior Member Joined: 08-December-2011 Location: Eagle Rock, CA Status: Offline Points: 498 |
I'm sure this has a lot to do with which tranny you'll be using. Which one will you choose, or do you have it already?
75 Ranchero in progress
04 Harley Deuce stage one kit 89 Toyota pickup modded 09 Scion XB (bought for the ol' lady) buy American! (sorry) skateboard 4 bicycles 1 scooter 2 dogs 2 stupid cats |
75GranMan
The tunnel hump is basically the same for floor shift auto and top loader 4spd. postion is the same for both. the 4spd hump has a provisions for the rev light wiring.... A small hole on the driver side.I have come across some floor auto shift humps with the small hole as well,just with a rubber plug in it. I have only used a factory shifter for my 2 top loader conversions.If i were racing my 4spd car. I would change to a hurst super shifter,But I believe it wont work with the factory console. Anybody tried this? |
Scott
I don't have the tranny yet but it will be a 72-73 factory 4 speed trans if I do it.
unlovedford
These are the Toploader ID numbers for a '72-'73 Gran Torino Sport 4 speed. They are on a riveted tag affixed to the transmission body:
RUG-BF 1972 Fairlane 351 wide Before 12/1/71 28-spline RUG-BF1 1972 Fairlane 351 wide After 12/1/71 28-spline RUG-BG 1972 Fairlane 351 wide Before 12/1/71 31-spline RUG-BG1 1972 Torino 351 wide After 12/1/71 31-spline RUG-BG2 1973 Torino 351 wide 31-spline ** Ignore the Fairlane designation, as Ford will sometimes use that for reference to Midsize units ** |
unlovedford
A very cool trick is to find a '77-'78 Granada with the 4 speed option. These Toploaders were built with a .81 "4th" gear. These gears can be retrofitted into an earlier case to get a cool overdrive transmission and still keep the Toploader. It was an iron case as well.
Eliteman76
I read that those are not technically a top loader? I'm probably wrong but I swore David Kee had something on his website about that.
I'm running a competition shifter, my understanding this was what my car came with. Also, with my console, its a bit close when I toss in to reverse...but no issues. I still need to buy a reverse light switch and the bracket. Mine was lost to the sands of time. Edited by Eliteman76 - 31-August-2013 at 5:08AM |
Pondering: #99Problems |
http://www.davidkeetoploaders.com/imposters.htm
40 some years after the fact, you can find anything as far as trans tags go. my trans is RUG-AR, which is supposed to be a Close Ratio for a 1970... somewhere along the line it became a Wide Ratio. 99% of the time, especially when it ~just has to work again~ strange things happen on the builders bench anybody got an extra factory Ford reverse shift rod for a 72 4 speed?
Edited by Rockatansky - 31-August-2013 at 8:16AM |
lynchster
Psquare75
David Kee is so afraid of those OD toploaders yet quite a few Power-Tour guys use em. Who power shifts from 3rd into 4th anyway?. I was going to do one in my F100, but a TKO seemed to be cheaper and easier in the long run.
unlovedford
I've had a couple of them in Granadas and while mine were driven pretty easily, they seemed to have no real issues. Bad press made them appear worse than they were, and when hooked to a 250 six the spread between 3rd and 4th was pretty wide. Nothing huge, but enough to notice with 90 horsepower. Add another 100 and you'd not really notice.
If I could find one, I would do that swap into one of the spare Toploaders I have sitting in the garage - just to eliminate a lot of hassle adapting a 5 speed to a Cleveland. |
Eliteman76
Not that big a hassle. Tko 500, have the input swapped to the shorter shaft, my case upgrade the shifter for pads for hard shifting, reuse toploader bellhouse and linkage.
I know of a couple toploader Granada units in the yard two hours from Omaha. |
