4 SPEED SHIFTER BALL |
SEKCOBRA ![]() Senior Member ![]() Joined: 27-November-2012 Location: NY Status: Offline Points: 575 |
![]() ![]() ![]() ![]() ![]() Posted: 23-May-2022 at 9:03AM |
Anyone have or know where to get the correct shifter ball for a 72 with a manual trans? Just received one from autokrafters and of course it is to small a opening to screw on my stock hurst shifter rod.
69 MACH R CODE
70 TORINO COBRA J CODE 71 TORINO COBRA J CODE 72 Z28 CAMARO 94 MUSTANG 5.0 LX NOTCH 72 GTS Q CODE 61 Galaxie 427 62 Galaxie 406 tri power 64 Galaxie country sedan 390 1972 GTS Q CODE |
Yellosn ![]() Member ![]() ![]() Joined: 14-February-2020 Location: Eugene, OR Status: Offline Points: 82 |
The thread is 7/16-20 for the stock shifter. I’ve seen a couple come and go on eBay, sometimes as a unit with the shifter and sometimes just the knob. There’s currently a stock pinto knob on eBay. Not sure if it’s the same.
I ordered a white one from these guys.
Edited by Yellosn - 23-May-2022 at 9:46AM |
Troy Emerson
Eugene, Oregon 1972 GTS 4speed |
Thanks, Just ordered one in black
69 MACH R CODE
Cool! I’ve been eyeballing that old school t-handle with the shift pattern on it. 😎
Troy Emerson
Yes. I like that also. Had that in my 70 torino cobras. Not correct for 72. Just didnt think it would look right. But you never know till you try.
69 MACH R CODE
handsofstone ![]() Senior Member ![]() Joined: 13-April-2018 Location: Northeast Status: Offline Points: 3471 |
I have a black one that is pretty well worn and want to dig the grooves deeper with a dremel and lay some white paint in it then try polishing it. Going to chuck it in my drill press to do it.
lynchster ![]() Senior Member ![]() ![]() Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 2033 |
I did mine without the Dremeling. Should be fine .
Mine is so worn you can barely make out the pattern.
Not sure of the accuracy, but this claims the t-handle was factory installed?????
Troy Emerson
T handles were factory on 70-71. Never saw or heard of a 72 having them from factory. Doesn’t mean it was not possible.
69 MACH R CODE
I ordered one of the “open 4”s, couldn’t help myself! 😂
Troy Emerson
Build it how you want it £
69 MACH R CODE
