  New Posts New Posts RSS Feed - 4 SPEED SHIFTER BALL
SEKCOBRA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Topic: 4 SPEED SHIFTER BALL
    Posted: 23-May-2022 at 9:03AM
Anyone have or know where to get the correct shifter ball for a 72 with a manual trans? Just received one from autokrafters and of course it is to small a opening to screw on my stock hurst shifter rod.
69 MACH R CODE
70 TORINO COBRA J CODE
71 TORINO COBRA J CODE
72 Z28 CAMARO
94 MUSTANG 5.0 LX NOTCH
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406 tri power
64 Galaxie country sedan 390
1972 GTS Q CODE
Yellosn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yellosn Quote  Post ReplyReply Direct Link To This Post Posted: 23-May-2022 at 9:40AM
The thread is 7/16-20 for the stock shifter. I’ve seen a couple come and go on eBay, sometimes as a unit with the shifter and sometimes just the knob. There’s currently a stock pinto knob on eBay. Not sure if it’s the same.
I ordered a white one from these guys.
Edited by Yellosn - 23-May-2022 at 9:46AM
Troy Emerson
Eugene, Oregon
1972 GTS 4speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 24-May-2022 at 10:10AM
Thanks, Just ordered one in black
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yellosn Quote  Post ReplyReply Direct Link To This Post Posted: 24-May-2022 at 10:51AM
Cool! I’ve been eyeballing that old school t-handle with the shift pattern on it. 😎
Troy Emerson
Eugene, Oregon
1972 GTS 4speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2022 at 11:36AM
Yes. I like that also. Had that in my 70 torino cobras. Not correct for 72. Just didnt think it would look right. But you never know till you try.
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2022 at 6:25PM
I have a black one that is pretty well worn and want to dig the grooves deeper with a dremel and lay some white paint in it then try polishing it. Going to chuck it in my drill press to do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 08-June-2022 at 5:41PM
I did mine without the Dremeling. Should be fine .
08 Taurus (Maytag)
03 Dakota (Rusty)
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 08-June-2022 at 6:10PM
Mine is so worn you can barely make out the pattern.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yellosn Quote  Post ReplyReply Direct Link To This Post Posted: 08-June-2022 at 6:42PM
Not sure of the accuracy, but this claims the t-handle was factory installed?????
Troy Emerson
Eugene, Oregon
1972 GTS 4speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 09-June-2022 at 2:01AM
T handles were factory on 70-71. Never saw or heard of a 72 having them from factory. Doesn’t mean it was not possible.
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yellosn Quote  Post ReplyReply Direct Link To This Post Posted: 09-June-2022 at 8:20AM
I ordered one of the “open 4”s, couldn’t help myself! 😂
Troy Emerson
Eugene, Oregon
1972 GTS 4speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 09-June-2022 at 8:22AM
Build it how you want it £
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
This page was generated in 0.113 seconds.
