400 crank |
pyntre
Senior Member Joined: 29-March-2007 Location: United States Status: Offline Points: 205 |
Posted: 18-April-2022 at 8:26AM |
Looking for info on a 400 crank , is there a better year than others as far as quality , is anything over .20/.20 not worth putting into a new motor , and actually locating one !?!?
Are any of the crank manufacturers making a new 400 crank , other than TIM Meyer ? Rebuilding the 351m , 208 thousand miles on it . Any up to date /2022 info would be great ! Thanks
any luck? FWIW Tim doesn't make cranks but he does source them from trusted / quality vendors another direction you can take is using a 351W crank with 3" main journals and a 4" stroke but you'll want to use the lightest weight pistons & rods you can because the 351W crank counterweights should be smaller / have less mass but aftermarket cranks may not be as much different from a factory 400 crank if that makes sense. factory 400 cranks have big / large mass counterweights, 351W cranks not so much but the aftermarket trend seems to be that the counterweights are bigger than stock. so what's up?
pyntre
Just bought a 400 motor and trans out of a 79 Lincoln ,112000 miles , picking it up in the next few days . Runs great , so I will use that to rebuild and keep the down time to a minimum on my car
