  New Posts New Posts RSS Feed - 400 crank
400 crank
pyntre View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Topic: 400 crank
    Posted: 18-April-2022 at 8:26AM
Looking for info on a 400 crank , is there a better year than others as far as quality , is anything over .20/.20 not worth putting into a new motor , and actually locating one !?!?
Are any of the crank manufacturers making a new 400 crank , other than TIM Meyer ?
Rebuilding the 351m , 208 thousand miles  on it .
Any up to date /2022 info would be great !
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2022 at 5:42AM
any luck? FWIW Tim doesn't make cranks but he does source them from trusted / quality vendors
another direction you can take is using a 351W crank with 3" main journals and a 4" stroke but you'll want to use the lightest weight pistons & rods you can because the 351W crank counterweights should be smaller / have less mass but aftermarket cranks may not be as much different from a factory 400 crank if that makes sense. factory 400 cranks have big / large mass counterweights, 351W cranks not so much but the aftermarket trend seems to be that the counterweights are bigger than stock.
so what's up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2022 at 7:10AM
Just bought a 400 motor and trans out of a 79 Lincoln ,112000 miles , picking it up in the next few days . Runs great , so I will use that to rebuild and keep the down time to a minimum on my car
