  New Posts New Posts RSS Feed - 429 air cleaner
429 air cleaner
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Topic: 429 air cleaner
    Posted: 25-March-2023 at 1:46AM
I am looking for a picture of a stock 1973 Torino 429 air cleaner set up.  I want to have one for the stock look when going to car shows but haven't been able to find a pic on the web.  thanks -  dave
Dave - 1973 GTS N code
RacerJames View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RacerJames Quote  Post ReplyReply Direct Link To This Post Posted: 05-April-2023 at 11:58AM
Don't know if this is helpful, but I have an air cleaner from the '68 T-bird I drove in high school.
'73 Torino Stock Car
'71 Mustang Stock Car
351C powered
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 05-April-2023 at 12:42PM
I don't have a Torino pic, but here is one from a 1973 LTD, which I believe is the same for the most part. The 400 powered cars also used the same sized air cleaner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 07-April-2023 at 1:44AM
Thanks Vince and James, those pics will help!
rcougarman View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote rcougarman Quote  Post ReplyReply Direct Link To This Post Posted: 07-April-2023 at 6:46AM
My first Torino had the 1973 429-4V.  It looked like the 1972 version, but it had a Hemholtz resonator about 180 degrees opposite the snorkle.  The resonator was made (literally!) from the same can used on FL-1 Motorcraft oil filters.
I had the great pleasure of working for a time in the early 2000's with the retired head of Ford powertrain and he confirmed that my thoughts were accurate about the filter housing being used.  Not sure if they used this arrangement on anything other than the 73 model, but it might have shown up on 460's afterward.
The resonator was to reduce engine air intake noise.  Other than adding a tiny bit of weight it didn't reduce engine performance (or help it).
72GTS now
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2023 at 3:39AM
I've seen those in some pics, always wondered what their purpose was, thanks, Randy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 16-May-2023 at 3:34PM
Weren’t there ones that had an aluminum aircleaner cover, too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote RacerJames Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2023 at 4:40AM
If I remember correctly, the aluminum air cleaners started in '79 or 80 with the LTD body change.
351C powered
This page was generated in 0.074 seconds.
