  New Posts New Posts RSS Feed - 429 SCJ -520
429 SCJ -520
Dmarc28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmarc28 Quote  Post ReplyReply Direct Link To This Post Topic: 429 SCJ -520
    Posted: 28-August-2022 at 4:28PM
Hey everyone heres ail update as to the progress on my engine.
I had a 429 SCJ built and was finally able to pick it up out in Colorado.
Finally was able to put it on today.
Here's some pics I'd the process. Hopefully  they are the correct view.
Now that its in i have some miscellaneous  things that need to be done so Ii can drive it. Hoses, drive shaft, exhaust, shifter linkage .
The shifter placement is off jus a bit. Need some advice on fixing that.
Any and all suggestions are welcome.
This view is looking straight down in the cab.
Here's the specs.
603hp @ 5600 rpm
638 ft/lbs @ 4300 rpm
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2022 at 6:46AM
What bellhousing kit is that? Do you have the hydraulic clutch setup?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2022 at 7:42AM
what shifter do you have? the factory Ford / Hurst has an offset arm bracket.
the round bar is 1972 and the flat bar is 1971 or 1973 i forget which ATM
as does the aftermarket Hurst Competition Plus shifter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2022 at 11:33AM
Move/remove the shifter hump bracket.
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 05-September-2022 at 1:15AM
Is there any value in a seized 429
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 05-September-2022 at 3:03AM
Depends on what seized.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 05-September-2022 at 7:02AM
All it said is won,t turn over. It,s a 72 ranchero It's on the other side of Connecticut or new Hampshire .300mi to far to go look
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmarc28 Quote  Post ReplyReply Direct Link To This Post Posted: 05-September-2022 at 3:31PM
Its a lakewood 429/460 bellhousing. I am using mechanical clutch linkage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmarc28 Quote  Post ReplyReply Direct Link To This Post Posted: 05-September-2022 at 3:32PM
I have the exact shifter you sent the link for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 05-September-2022 at 6:10PM
My 73 has the round shifter.
This page was generated in 0.104 seconds.
