460 Clutch Linkage |
MZSCJ
New Member Joined: 05-April-2015 Location: Sussex, WI Status: Offline Points: 35 |
Posted: 08-May-2016 at 3:26AM |
Can anyone help me out on what clutch linkage parts to use. I have 460 and a Lakewood scatter shield and big input toploader. The engine side linkage pivot doesn't line up correctly. Any help would be appreciated
aquartlow
Senior Member Joined: 19-December-2011 Location: Summerfield, Fl Status: Online Points: 2271 |
Is there a hydraulic slave cylinder "upgrade" available? Does away with the mechanical linkage issues. If this is not a route that can be taken, welding or fabbing up a different mount may be in your future. Good luck.
how far off is it?
MrSmog
factory big block mounts for the 72-76 cars? length of trans the same as to where it mounts and where bell housin seam would be? I would think even though they never offered a factory big block 4 spd in these cars, it should all line up with factory engine mounts. I may do this as well, so very interested what you find out. I'll probably use my original small block trans though and just take a little off the front shaft to work with a big block (3/8" i think) as they are strong enough behind a stock or mild big block. They used small shaft top loaders behind 390's
75GranMan
They never produced a big block 4spd. Those who have converted to a BB 4spd say If you use a factory bellhousing, you can modify the SB bracket to fit.
MZSCJ
Thanks for the replies. I'm looking into the hydraulic set up. I'll let you know that I find out.
