460 manifold |
Post Reply
| Author | |
1974xr7
Joined: 26-October-2007 Location: Bassett,Va Status: Offline Points: 228 |
Quote Reply
Topic: 460 manifoldPosted: 20-August-2014 at 4:45AM |
I have a right side manifold off a 460 form an 83 ambulance. Obvioulsly I have to weld up the EGR holes but will it fit otherwise in my 74? |
Always looking for 1974 Q codes
kychevyguy
Joined: 16-December-2013 Location: Lexington KY Status: Offline Points: 1996 |
Quote Reply
Posted: 20-August-2014 at 5:40AM |
Easier than welding it up, they have EGR block off plates that you can just bolt right on.
JT, USAF Ret./Architect
Joined: 25-August-2013 Location: New York Status: Offline Points: 4195 |
Quote Reply
Posted: 20-August-2014 at 5:50AM |
If you mean the pipes for the smog pump/AIR system, take the pipes and fittings out and put in pipe plugs
1974xr7
Quote Reply
Posted: 20-August-2014 at 6:18AM |
The EGR ports we will block off. My concern was the exit of the manifold. Ii appears to be oriented a little different. Just wondering if anyone had used one of these. Wanting to make sure it clears the transmission.
Quote Reply
Posted: 20-August-2014 at 10:27AM |
The transmission shouldn't be a problem, as it's going to be a C6 in either vehicle. Things that may not clear would be the heater/AC, firewall, frame.
Post Reply
| Tweet |
