  New Posts New Posts RSS Feed - 4spd transmission mount.
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: 4spd transmission mount.
    Posted: 20-September-2022 at 3:02AM
Hello forum. I have my car in pieces atm.👍🤠. The tranny mount is rotten/busted. I have to change it.
What is a good replacement? Polyurethane is fine too.
Will this kit fit?👇thanks….
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 20-September-2022 at 6:11AM
Dammit!…crossmember nut wont come off……a lot off troubles with the GTS atm!😵‍💫
What do you fellas do? I cant get to the top of the bolt, as it isinside the frame…
Wayner315 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayner315 Quote  Post ReplyReply Direct Link To This Post Posted: 20-September-2022 at 9:16AM
Should be a tab that lodges in the frame to stop rotation. Mine broke off so just cut that bolt off. then welded a new little plate to a nut for reinstall.
Yellosn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yellosn Quote  Post ReplyReply Direct Link To This Post Posted: 20-September-2022 at 9:28AM
You’re not alone. Here’s a post with some good info.👍
Troy Emerson
Eugene, Oregon
1972 GTS 4speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2022 at 6:30PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayner315 Quote  Post ReplyReply Direct Link To This Post Posted: 22-September-2022 at 3:03AM
I believe matching the trans mount material to the engine mount material is important to avoid vibration issues?
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2022 at 1:55AM
Go with rubber. Poly will transmit  noises and you will think something is broken.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2022 at 4:07AM
Yes…rubber it is. Thanks.
