  New Posts New Posts RSS Feed - 5x114.3 wheels do not bolt up.
shanewherry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shanewherry Quote  Post ReplyReply Direct Link To This Post Topic: 5x114.3 wheels do not bolt up.
    Posted: 04-January-2024 at 8:20AM
Hey guys.
1973 Gran Torino wagon with the 6.6L/400 cid engine. The forums say that I need 5x114.3 bolt pattern wheels. That is what my Lincoln town car is and wheels do not bolt up to my Wagon. I tried Mustang ones and they are close but do not fit. Are my studs a 5x139?
Shane
1973 Gran Torino Wagon
400/C6
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2024 at 9:20AM
is it the wheel offset or the lug circle diameter that is the issue?
is the wheel hitting the brake or suspension before it reaches the studs?
5x114.3 is the late model high offset stud circle designation. a high offset wheel has little 'dish' protrusion and the lug flange is almost flush with the edge of the tire
5-4.5" is the designation used back in the day for low offset wheels like those that fit your 73 wagon. the lug flange is about in the center of the outside hoop and set back from the edge of the tire
to use high offset wheels on older cars you'd need a stack of spacer plates and that's never recommended
are you sure your wagon is not 5-5" wheel stud diameter?
Edited by Rockatansky - 04-January-2024 at 9:25AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2024 at 1:48PM
Could it be a center pilot issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2024 at 1:57PM
Right? could be the hub register but i think the newer wheels have a larger diameter than the older ones?
Edited by Rockatansky - 05-January-2024 at 5:06AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2024 at 2:55PM
 IIRC, a '73 wagon uses 5 on 5" wheels. Not 100% sure though
Post Options Post Options   Thanks (0) Thanks(0)   Quote shanewherry Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2024 at 4:13PM
I should be more specific. The wheel studs do not line up to the wheel holes. They are close but not close enough.
400/C6
Post Options Post Options   Thanks (0) Thanks(0)   Quote shanewherry Quote  Post ReplyReply Direct Link To This Post Posted: 05-January-2024 at 2:24AM
Ok so did a little research or playing around and I noticed the studs on the gran Torino are bigger than the Mustang or Panther platforms. That is why those wheels will not work unless you drill out the mounting holes slightly bigger. Possibly why the ranger/explorer wheels fit because of the stud hole on the rims are slightly bigger.
400/C6
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 05-January-2024 at 5:29AM
all should be 1/2"-20, i have 2 Panthers here as well as a 72 Ranchero, all will accept the same lugs. and i've used Mustang wheels on both Crown Vics, Mustang, Explorer, Escape, Crown Vic all accept the same wheels AFAIK
Panther wheel & tire info thread,
Post Options Post Options   Thanks (0) Thanks(0)   Quote shanewherry Quote  Post ReplyReply Direct Link To This Post Posted: 05-January-2024 at 1:09PM
Ok sounds good. I have a set of PPV Crown Vic wheels I want to use on the Gran Torino.
400/C6
Post Options Post Options   Thanks (0) Thanks(0)   Quote shanewherry Quote  Post ReplyReply Direct Link To This Post Posted: 05-January-2024 at 1:25PM
I see the issue now. Backspacing on the Crown vic wheels make it so they can not fit the gran torino without 2” wheel spacers. 🤦🏻🤦🏻🤦🏻🤦🏻🤦🏻🤦🏻🤦🏻
Back to finding some steel Ranger/B3000 wheels
400/C6
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 05-January-2024 at 1:59PM
have you measured the studs on the wagon like the diagram i posted above shows?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 05-January-2024 at 5:04PM
I have fit 2004-2005 GT mustang wheels but with the high offset and need for spacers, sold them to a kid with a Subaru that takes the same bolt pattern.
Honestly, Ranger / Mazda pickup wheels for the 90's - 2000's will fit good and allow you to run a 255/60R15 or similar sized tire no issues.
Never tried a 275/60R15 but that might be a tad wide for those ranger steelies.
Another option would be 1st and 2nd gen Explorers and Mercury Mountaineer SUV's.
Ford Aerostars sometimes had 15x7" wheels.
15" tires are also getting to be a joy to locate.
Alternatively up to 2000 Crown Vics had a 16" steely with correct offset but 16" car tires are a pain to find these days.
