  New Posts New Posts RSS Feed - 67 falcon speedo cable?
Grantorinosport351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Topic: 67 falcon speedo cable?
    Posted: 31-March-2014 at 2:49PM
Sup fellas, I need a speedo cable, and I can't seem to find one that says "will fit 67 ford falcon" will any speedo cable fit? It's a c4 tranny, and I need something other than the cut off speedo hangin out lol, what I'm worried about is the fitment to the dash.......what do I do if I change the gear ratio? Won't that be off?
~Bryan
72 gts h-code (formal roof)
67falcon
04 f250 ''the great white''
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2014 at 4:22PM
you can change the gears on the cable end if it's not too far off. the problem with mine is- mine was dead on, put in the aod it has the other gear machined into the output shaft like my fmx 8 tooth vs 7 tooth i can't get a 15 tooth speedo gear they don't make one that small i had 17/8 now i need 15/7Angry but if you get a cable working you can use a GPS to check your actual speed then try different gears
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2014 at 4:35PM
I know that there is a gear on the end of the cable, that's not set perfect for your tranny? You change it for you gear ratio?
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2014 at 4:48PM
yes depending on how much and which way roughly  1 tooth is about 5mph???  too fast go bigger gear. different geared rear end changes things different tires changes things, just trial and error, run what gears you have and see how much it's off at what speed(s) make a note of that try it at like 25 mph and at 50 mph note how far off it is and go from there, make sense?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2014 at 4:54PM
Yeah thanks,so I found a cable, I can just pull the gear off of the cut off cable and put it on the new one? I have also been wondering, can a cigarette lighter outlet be used for say a phone charger? Or gps?
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2014 at 4:59PM
yes on the lighter if it worksWink the gear has a "C" clip holding it in place  is your speedo like the torino? or screw on type?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 31-March-2014 at 5:08PM
Haha, that's what I was thinking. (It doesn't...lol) but I'm not sure about the type, the cable is cut on it currently, about 3 inches away from the tranny. And I'll have to pull the cluster to look, but I think it's the screw on type.
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2014 at 4:25PM
does the bottom end screw on or slide into the tranny?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2014 at 4:26PM
Slide in
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2014 at 4:27PM
I just ordered a cable, I'm hoping it fits, it said 67 falcon speedo.
~Bryan
67falcon
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2014 at 4:43PM
i'm thinking the stock cable should work and fit the tranny
we need a "fingers crossed" emoticon smiley thing!!! hint, hint!
Edited by californiajohnny - 01-April-2014 at 4:44PM
