68 "Glue in windows" |
OLDSCHOOL ![]() New Member ![]() ![]() Joined: 04-November-2014 Location: Georgia Status: Offline Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 10-November-2014 at 6:43AM |
The last thing, and most aggravating thing that I need to get done before I can turn my son loose is getting the door windows reset. When I bought the car, both sides looked like they'd been re-glued (and not very good). The big problem I'm having is knowing the exact place the channels are glued on. There was no factory sealant in the channels, or marks on the glass to give me an accurate position. If anyone has ever had experience with this, I'd appreciate some input. I've ordered manuals, and asked around, but nothing so far.
68hardtop ![]() New Member ![]() Joined: 23-June-2013 Location: bc Status: Offline Points: 29 |
My friend a Torino guru once lent me a jig he made for doing the windows. It is slick, works well.I am do to see him this week I will try to get some pictures and measures
rafaelmd ![]() Brand New Member ![]() Joined: 30-October-2020 Location: Brazil Status: Offline Points: 1 |
Hi. Its been 6 years. Anyone know the right spot, measurements from the edges of the glass to glue the channels? thanks
piper62j ![]() Member ![]() ![]() Joined: 21-July-2018 Location: 34613 Status: Offline Points: 109 |
This is what I have done over the years in our body shop. (You can use any type of glass adhesive to secure the window to the mount. Just don't use silicone). Center the glass with the fiber padding into the holder using the adhesive and gently crank the window up to the stops where it is positioned both upward and forward against the weatherstrip with the door closed.. Secure the glass to prevent it from coming free of the holder until the adhesive cures. I usually taped the window crank in the position it stops at when the window is up.. Also, I used tape to secure the window on the outside to the roof as an added measure.. Let the adhesive cure and remove all the tape. We used the 3M 08690.
2ndtimearound ![]() Brand New Member ![]() Joined: 08-November-2020 Location: Upland Californ Status: Offline Points: 1 |
In 79, I had to reset my 69 Torino drivers windows in their tracks and recall that went without issue. If I recall, the markings were still on the windows.
This past week, I bought a 68 Torino GT convertible and it was delivered to me last Sunday and again the drivers side window came undone from its track. However, the glass was not clearly marked, it was super dirty and no clear marks. When I RTV'd it back in place quick, I guessed and set the back mount too far to the right and when fully extended up, the glass is short of the weather stripping by about a 1/4". So, I know now what the measurement should not be and I will go out and check and report back what the measurement should, in fact, be. As, I need to redo mine as well.
