  New Posts New Posts RSS Feed - 69 Ranchero Brake Differential Pressure Switch
jimh1956 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimh1956 Quote  Post ReplyReply Direct Link To This Post Topic: 69 Ranchero Brake Differential Pressure Switch
    Posted: 17-March-2026 at 4:00AM
The piston in the brake differential pressure switch was stuck at the rear brake end, air pressure would not free it. I made a plug for one port from a brake line, 1/4 tubing and 7/16-24 thread and a grease fitting adapter for the opposite port, same thread. Applying grease gun pressure, the piston came out readily. Bronco Graveyard supplied the new seal kit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 17-March-2026 at 5:19AM
Nice, and what, bread wouldn't do it like a throw out bearing? Good work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimh1956 Quote  Post ReplyReply Direct Link To This Post Posted: 17-March-2026 at 8:58AM
Source was Dennis Carpenter not Bronco Graveyard. Thanks.jh
This page was generated in 0.074 seconds.
