  New Posts New Posts RSS Feed - 70 Cyclone GT w/Boss 466
profaqualung View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote profaqualung Quote  Post ReplyReply Direct Link To This Post Topic: 70 Cyclone GT w/Boss 466
    Posted: 29-January-2013 at 12:52PM
http://i880.photobucket.com/albums/ac6/profaqualung/img440.jpg?t=1359497647
Some of the story and some more pics of this setup are now in the "Project Update" portion of this forum -  "70 Cyclone GT Boss 466"
P A
Shoot low sheriff, she is riding a Shetland
1970 Cyclone GT Boss 466
Armadillo Breeders Association
1974xr7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1974xr7 Quote  Post ReplyReply Direct Link To This Post Posted: 31-January-2013 at 5:40AM
Wow!! Beautiful!!
Always looking for 1974 Q codes
torinojon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2013 at 4:00PM
hi
on a nother post you said you have 8 up front.i was wondering whats your off set and tire size is... torinojon
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2013 at 4:07PM
hi
i got 15/10 (295/50/15)on the back of my merc.i got 15/8 for the front but i didnt think thay fit up front.the rims are stock off set.i got some 245/60/15 tires for the fornts.whats your set up..torinojon
Post Options Post Options   Thanks (0) Thanks(0)   Quote profaqualung Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2013 at 7:43PM
Torinojon -
I am running 215/65X15 in the front and 295/50X15 in the rear - both on 8" rims.
Have a good friend in the Dallas area running the same tires, but is using 10" rims in the rear - makes an already wide tire look wider.
Hope this helps.
PA
Post Options Post Options   Thanks (0) Thanks(0)   Quote profaqualung Quote  Post ReplyReply Direct Link To This Post Posted: 15-April-2013 at 12:27PM
Torinojon -
I just found the post you were refering too.  As you already have the 295/50's mounted on 10" rims, you already know they look 'wider' than when mounted on 8" rims.
As far as offset, I have know idea - when I ordered the rims [from JEGS] I was told the offset was the same as stock - is it? - I have no idea.
The rear end is a Currie 9" Ford unit - giving me discs all the way around - and an ABS electric/hydraulic power break unit.
Thought seriously about a manual trans when building this beast.  Was going to try to replicate the fun I used to have in the mid 60's with my 421 super duty Catalina - ex John Zink drag car - ex Smokey Yunick NASCAR car - converted to street use.  But my mechanic and others reminded me that my legs are not what they used to be.  And I am glad they did.  The Merc would not be near as fun if it was a standard.
With the auto and the GearVendor. it makes for an 18 mpg road car, that has a tire busting passing gear at 91 mph - and will do nose to tail cruise-in traffic with no problems.
PA
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2013 at 6:22PM
hi,good talking with you.i got a 71 montego im building for me.the car started with 4 wheel drums but now has 4 wheel disks.i dont got abs but that anther deal.i put a 78 linc versailles in the back to get the room for the 10" rims.im gona try to put the 245/60/15 on my 8" rims for the fronts and see what happens.i got the t/l 4speed in it now form auto but want a t/5 5 speed in it.ill try to get a pic of the back of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 02-May-2013 at 2:47PM
                                   this is what it looks like from the back.
Edited by torinojon - 02-May-2013 at 3:55PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 02-May-2013 at 3:58PM
the back view
Edited by torinojon - 02-May-2013 at 4:01PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 02-May-2013 at 4:02PM
side view
Edited by torinojon - 02-May-2013 at 4:04PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote profaqualung Quote  Post ReplyReply Direct Link To This Post Posted: 03-May-2013 at 2:09PM
After seeing your pic, and a couple of others posted in the '70-71 Mercury Cyclone' group on facebook, I ordered a pair of 15X10 rims for the back today.  Just cannot believe how much wider they appear mounted on a 10" rim instead of an 8" rim.
Now if it could give me the illusion of having some traction, I would really appreciate it.
PA
Forgot to add one thing.  If you go to facebook, you might also check out the Jon Kaase Racing Engine page - they have posted a video of a Kaase Boss9 powered 70 Torino, that just won top honors at a Corvette Show.  It is OUTSTANDING!
Edited by profaqualung - 03-May-2013 at 4:05PM
This page was generated in 0.101 seconds.
