  New Posts New Posts RSS Feed - 71 Ranchero GT questions
Bretticuss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bretticuss Quote  Post ReplyReply Direct Link To This Post Topic: 71 Ranchero GT questions
    Posted: 10-July-2025 at 11:33AM
Hello, here is my 71 Ranchero GT (351C 4bbl, C6). I'm wanting to treat her right and basically restore her. I can't directly share pictures here due to being a new member, so heres an IMGUR link
 https://imgur.com/gallery/71-ranchero-gt-MOVe1Dx
 I've got a few questions for everybody:
I want to convert to powered disk brakes, what kit is everybody using? Anything I need to know when doing a conversion? I'm fine with doing just front disks for now, but eventually I want to convert my rear to disk as well.
How are these fuel lines? Or am I better off just bending my own?
https://www.sstubes.com/products/dgl7002ss-70-71-ford-ranchero-2pc-3-8-tank-to-pump-fuel-line-stainless?variant=39385898942646&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gad_campaignid=22106649052&gbraid=0AAAAADkJcVvD_JVRn9U2OvEhymYdCs7ah&gclid=CjwKCAjwyb3DBhBlEiwAqZLe5D8as43yBVMJna--mvjY6MP-SEzQ6ZAaSBn8id_yWllqrOD_4acy9RoC9ZkQAvD_BwE
Any good suspension upgrades out there?
What headers for a 351 Cleveland with power steering?
Who makes the best replacement body panels? I need a new driver floor, cowl needs some patches, and so do the rear quarter panels.
I have a clutch pedal, but its for sure an automatic. Just thought that was interesting.
The interior is pretty shot on this car as well.
I'm sure I will come up with more questions as time goes on, thank you all!
Brett
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2025 at 1:23PM
Welcome Brett. You should be able to post pictures very soon, you'll be upgraded as soon as the administrator sees your new membership.
I think you can buy most of those things you asked about, those are typical part upgrades and many others have gone through them.
What are you planning for that Cleveland, I love hearing about them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2025 at 4:24PM
Welcome to the forum!  You have been upgraded to a new member so you have full forum access. You will be able to also upload photos to the forum.
Try Macs, Auto Krafters and Auto Metal Direct for replacement panels.
Wilwood offers disc brake kits.
Auto Krafters has a kit:
And MP Brakes:
Hooker has some headers that fit your car.  I can't speak to the fit on a 71, but the Hooker Super Comps on my cars are great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bretticuss Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2025 at 3:26PM
I found a ton of those upgrades for sale, just curious what everyone else has used that has went well for them.
I don’t know a whole lot about Cleveland’s, and in general I’m new to older engines. I currently just want to get it running good, the cars been sitting for a while. I’m thinking some headers, a good cam, and maybe some new heads in the long run.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bretticuss Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2025 at 3:40PM
Awesome, thanks a lot!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2025 at 1:05AM
The budget will steer your spending, so concentrate on the things to get it driveable first. Then work your way to the other things and upgrades. Try not to buy things early on until you need them, unless you have a huge budget.
The engine might be relatively easy to get going and running good. But upgrades are an whole different level. Do your budgeting as you go, but once you reach the running fine level, then you should reevaluate what you want from the vehicle, what things really cost.
Then you can set a new budget for the engine or any other big ideas(paint etc). Wait until that running fine level before doing the latest planning, things change often with car projects. The old engines in like original combinations did run good, but nothing like today's stuff of course.
The Cleveland 4V was a much different engine than all other OEM small blocks, those heads made the potential easily a 100hp more than any other SB. But the stock cams and intakes, low compression after 1971, small exhaust etc, it all limited the engines to similar rpm ranges and power levels. The 351C-4V has the potential to make a bunch more power than other 70's engines above 6000rpm. If you use typical dual plane intakes and 70's tech cam technology, the high rpm will not be special at all. It will be like other small blocks, nearly the same power in that 3000-5000rpm range. Plus the bottom rpm's will be mediocre too.
So build yours to match what others commonly do, run a stock rpm range with similar parts, and get what everyone else gets, which is nothing special. But if you want more than that, spend a little more to upgrade to a roller camshaft and lifters, have the simple oiling system upgrade done(to run over 5000rpm), and make the compression at least 10:1 for sure. Use headers and the RPM Air Gap intake, plus the heads must be rebuilt with new valve seats, guides, and valves if they are original parts. You can run 6k or so with the stock pedestal rocker type, but the lift will have to be limited to about .550", aftermarket rockers are not expensive.
Don't use pedestal roller rockers, those are all too weak(the studs are tiny stock 5/16" bolts). The only decent roller rockers mount on 7/16" studs, which requires cutting the heads to install those. Those great aftermarket rockers plus the machine work is fairly expensive, most people skip that cost and choose lesser parts. Note that stud roller rockers are much louder, the sound bothers most people, and it takes great care to get the stud locking jamb nuts properly tight. The bolt down OEM type rockers are much quieter and more reliable almost always, so those should be a first choice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bretticuss Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2025 at 2:51AM
I definitely think I want to go the route you’re talking about. Do you have a parts list, and some more information I can read about that kind of build?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2025 at 5:26AM
Do continue as you are planning, there are going to be a lot of things you discover along the way that slow things down, cost more etc. Get it driveable for starters, it's much easier to work on or upgrade, than one that needs a lot more.
I've got plans to refresh my complete 73's 351C-4V. It has closed chamber heads and the prior owner stated he paid about 6k to have it built. But with no real receipts except for the cam and pistons, I suspect it might not have the oiling mods done yet, or the heads properly rebuilt. So I'll take it out and apart, to see what's there to work with.
So far I've just bought the RPM Air Gap intake, and a new set of 1.75" headers. It takes a long time for machine work to get done, expect months of time to wait for the shop you use. Spend plenty of time looking around for a decent trustworthy machine shop.
If my Cleveland turns out to be nice and usable, best case is to not have to modify the shortblock except in putting it back together with roller cam parts. I know the upgrade for that alone will be more than $1100, the lifters are critical and expensive, you have to carefully plan and measure the rockers and valvetrain geometry etc. If things turn out right, I'll have it shifting automatically around 6000rpm. The right cam and intake will make the 3500-6000 range very special. You shouldn't treat it like they did in the 70's, make the cam really big and don't let off the gas until you reach your rpm goal. It may get to 6500rpm or more, but with a "Performer" intake or similar, and flat tappet cam/lifters, it won't impress much.
The 4V heads are most happy at high rpm, but the stock type intakes and cams are much too small for those huge intake ports. What I'm saying is the combination of parts needs to be much better than any stock level 4V engine, and the oiling system is not adequate for much beyond 5000-5500rpm. The oiling system basic upgrades are not hard for any good machine shop to do, nor very expensive. So don't skip that and later discover spun bearings or other big failures from lack of oil at high rpm. It's not about the oil pump, that should be a good Milodon standard pressure pump.
It's not that hard to get it done, it's just time consuming and some more cost, plus careful selection of parts, and the assembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bretticuss Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2025 at 3:30PM
Thank you for all the information! I’ll definitely reach out to you when I get to that point in my project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2025 at 3:55PM
Don is a wealth of knowledge. Rockatansky on this forum is also our resident Cleveland expert.
Check out this project build of a '70 Torino that might give you some ideas for your engine build.  He ended up building a really nice Cleveland for his Torino.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bretticuss Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2025 at 3:50PM
I just finished reading the entire thread, really good stuff in there. I’m definitely going to reach out to them with engine questions, I’ve got a pretty good idea what I want from this car.
This page was generated in 0.108 seconds.
