  New Posts New Posts RSS Feed - 71 Torino wont start
erock194 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote erock194 Quote  Post ReplyReply Direct Link To This Post Topic: 71 Torino wont start
    Posted: 19-April-2015 at 1:53PM
I have a 71 Torino GT convertible with a 351W 2 barrel. I turn the key and get nothing. The top has power but nothing else. No headlights either. I have power to the coil and at the points when I jump it out at the starter solenoid. It cranks but doesn't start. The ignition switch is in bad shape so i am replacing it. Should the car start when its jumped even if ignition switch is no good? Thanks Eric
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 27-April-2015 at 11:05AM
the ignition switch is what gives power to the coil so if the switch is bad no it won't start
Torino Troy
Post Options Post Options   Thanks (0) Thanks(0)   Quote erock194 Quote  Post ReplyReply Direct Link To This Post Posted: 30-April-2015 at 9:36AM
Where do i find a switch for a 1970. Got on but it had wrong plug.
This page was generated in 0.106 seconds.
