  New Posts New Posts RSS Feed - 72 bucket seat question
SEKCOBRA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Topic: 72 bucket seat question
    Posted: 10-May-2021 at 4:45AM
Hi
Does anyone know 100% if 1972 cougar buckets are the same as a 72 Torino. Not the material but the seat frame and rails?
Thanks
69 MACH R CODE
70 TORINO COBRA J CODE
71 TORINO COBRA J CODE
72 Z28 CAMARO
94 MUSTANG 5.0 LX NOTCH
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406 tri power
64 Galaxie country sedan 390
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 10-May-2021 at 4:52AM
The 72 Cougar should be the same as the Thunderbird then, those had a different body(bigger) until about 1974? The Montego should be a cousin to the Gran Torino, those seats should be the same.
I have my old 72 GT seats, but I can't do without them unless I found a replacement(my wish is an 87-92 Supra power seat).
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 10-May-2021 at 5:10AM
Ok. Surprised that they are not the same. I have a guy local with a pair for sale. Dam I thought I found them. Thanks for the reply.
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
mkshelton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mkshelton Quote  Post ReplyReply Direct Link To This Post Posted: 10-May-2021 at 5:31AM
According to this thread, they will bolt right in. I don't know myself.  I do know that the bolt spacing is about 11.75 on center side to side and 12.75 oc front to back for our cars bucket seat arrangement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 10-May-2021 at 6:06AM
All of the bigger Fords of the 70's will probably have seats that can swap, the width might be a hair different based on the body width.
I didn't mean to suggest they couldn't work, I thought the question was are they the same seat frame etc, like you would recover them with OEM level material.
I would definitely go look at them, and also measure the seat frame bolt patterns. It's common for Ford to use seats with the same bolt pattern for most seat of a model run, various years etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 10-May-2021 at 7:48AM
72 Cougar is a Mustang chassis. Seats are narrower, mounting brackets are different, but seats might bolt to Torino sliders???
Cougar went to Torino/midsize chassis in '74. Tbird was a "MegaTorino" 72-76. (Same basic chassis, just longer/heavier/and even more heavier).
Tbird was a "prettier" LTD II 77-79.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 10-May-2021 at 9:47AM
Okay, right Mustang chassis. I recall the Mustang seats in my friend's two Mustangs, a 72 and 73. Those were as nice as the Gran Torino bucket seats, I wouldn't have guessed they'd be narrower.
DO go look at them, if the frame structure is all okay, you can have the foam and upholstery redone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 10-May-2021 at 9:49AM
The 72 Cougar should be the same as the Thunderbird(edit- Mustang) then. The Montego is the closest cousin to the Gran Torino, those seats should be the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 10-May-2021 at 11:27AM
Ok guys. Thanks for all the replys. I'm not in that big of a rush yet. Lol. I think I will wait to find seats from a torino, montego or ranchero. Going to Ford nationals at Carlisle in a few weeks. Maybe I can find them there.
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2021 at 9:16AM
Brackets themselves for the rails/sliders are different, to bolt to the unibody floor pan of the cougar.
The Tbird however shares with Torino for 72+
The seats themselves can be used with the sliders, I have not noticed a width difference.
Personally, I would actually use Torino seat rails, and find a set of fox body seats and get them redone.
I used foxbody/cougar XR7 buckets for a while until I redid a set of Lincoln mark 7 buckets.
I did have to fabricate spacer plates to adapt to the Foxbody/Mark 7 seats. My build thread details the plates I made. 3" long, and two holes spaced 1" apart with a stud welded on I want to say one of the plates, to bolt to the seat frame, otherwise all bolted together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2021 at 1:13PM
Thanks Andrew, that's good to know about the Thunderbird sliders/seat tracks. I have some 87 LSC seats to use in my 92 Mark VII, those earlier(1985ish-1989) LSC seats had nice shapes, and adjustable thigh bolsters. Those might be a good idea if they retrofit to the older Fords.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2021 at 4:11PM
Don, I LOVE my Mk7 seats in my GTS.
Now, I did recover them, and make new covers. Talk about a process!
If you look up my build thread "17 year barn nap" somewhere in all my rambling...it shows what I did on the seats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2021 at 12:31AM
That's great to hear. I have only ridden in an older Mark VII one time with those seats. My friend has owned several of them, and one that we parted out he saved the red seats from. He will give them to me, but they've been stored with something heavy on the cushions. So I need to get them reupholstered, and they will need some foam work of course. I could get to that sooner than later, if I knew I'd love those, I'd find others. Those have fairly compact power seat tracks, and have good access to most parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 18-July-2021 at 2:01AM
I have the seats out of my ‘73, and I have a set of 1970 mustang seats.  I’ll flip one of each over for a side-by-side comparison.
