72 GTS fuel tank question |
Tennessee-Jimbo
New Member Joined: 08-September-2022 Location: Anderson, SC Status: Offline Points: 11 |
Posted: 15-September-2022 at 11:45PM |
Hello fellow Torino enthusiasts. Need some advice please.
Finally getting my 72 Gran Torino Sport back on the road after sitting idle for about 8 years. So far, I have installed a new fuel filter, new mechanical fuel pump, removed the fuel tank and took it to a radiator shop and had it boiled out to get it cleaned up and installed a new fuel sending unit. I know the fuel pump is working as I disconnected the fuel hose between the fuel pump and the steel line that goes back to the fuel tank and feed the fuel hose into a 1-gallon gas can and the fuel pump pulled fuel up to the fuel filter and car cranked up fine. With the fuel hose connected back to the steal line going to the fuel tank, I put 2 gallons of ethanol free regular gas in the tank, but the fuel pump doesn't pull fuel from the tank. I guessing I simply don't have enough fuel in the tank yet to reach the fuel line/sock at the bottom of the sending unit. Can anyone tell me how many gallons of fuel has to be in the tank to reach the fuel line/sock at the bottom of the sending unit?
1972 Ford Gran Torino Sport Fastback
351C 4V 3-speed FMX AT |
handsofstone
Thanks(1)
I would think you have enough fuel in the tank. Did you match the parts? If the pickup is not near the bottom, it will never completely empty the tank.
Tennessee-Jimbo
Thanks for the reply. Yes, I matched the sending unit to what was in it before when it was running.
hogfiddles
Moderator Group Moderator Joined: 19-September-2016 Location: Central NY Status: Offline Points: 1512 |
Or you lost the prime when you unhooked the line
Tennessee-Jimbo
Thanks hogfiddles. Are you referring to losing the prime in the mechanical fuel pump? Does the steal line that runs back to the fuel sending unit have to be primed or if I prime the fuel pump, will it start pulling fuel from the tank?
hogfiddles
Thanks(1)
I would expect it to pull fuel, but if there’s too much air getting in the line, it may not suck the fuel
Did you make sure the pick-up was oriented in the correct direction when the sender was installed? If lt's installed in the wrong orientation it will need a significant amount of fuel before it can suck any. Have you disconnect the feedline at the sending unit at the tank? If it has enough fuel in there, it should naturally run out.
Tennessee-Jimbo
i will confirm that. Thanks.
Inkara1
Senior Member Joined: 17-November-2021 Location: Ridgecrest, CA Status: Offline Points: 283 |
Is there a clog in the line? Can you blow air in one end and have it come out the other end?
Tennessee-Jimbo
Thanks Vince. Sending unit is in the correct orientation. I loosened the clamp at the sending unit a fuel started leaking out, so I have fuel.
It will crank up and run for about 15-20 seconds and then die.
Tennessee-Jimbo
Thanks Inkara1, yes, I blew are into the steal line at the fuel pump and could hear air coming out in the tank.
hogfiddles
Are you sure you have the correct line to the carburetor?
1973gts
Senior Member Joined: 05-March-2018 Location: Grand Rapids Mi Status: Offline Points: 614 |
Thanks(1)
One quick question, when you had the line in the 1 gallon can you said it cranked up fine, how long did you run it, longer than the 15-20 seconds that it dies at in the normal hook-up? I'm thinking carb/choke might be involved?
Dave - 1973 GTS N code
Inkara1
Thanks(1)
Something else to maybe try: see if it'll get fuel if the gas cap is removed. That's to verify that the line between the tank and the charcoal canister isn't clogged or blocked off. If it is, and you have a non-vented cap, that could create a vacuum, making it so the pump can't suck out fuel because air can't get in to replace the fuel drawn out.
Tennessee-Jimbo
Thanks Inkara1. My gas cap is a loose fit so not sealed and causing a vacuum in the tank.
Tennessee-Jimbo
Thanks Dave. I will confirm this and let you know.
