  New Posts New Posts RSS Feed - 72 GTS Power Brake conversion
72MLC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72MLC Quote  Post ReplyReply Direct Link To This Post Topic: 72 GTS Power Brake conversion
    Posted: 11-May-2022 at 7:58AM
If asked before I'm sorry, I tried to search but didn't seem to find much. Is anyone aware of compatible or working systems to upgrade my manual brakes when the time comes? I saw Macs Auto had a system but seems permanent out. I've seen the hydro boosts but all I can find. Thanks!
DJsTorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJsTorino Quote  Post ReplyReply Direct Link To This Post Posted: 11-May-2022 at 4:13PM
I have a booster and the spacer that goes behind the dash. The booster needs restored (it functioned just doesn't look pretty) and you would need to fashion a gasket between the booster and fire wall. I converted my car to standard brakes this winter.
You will also need to drill and weld in a new pin for the brake push rod on the brake pedal. Its a pretty large undertaking, and honestly my brakes now feel very similar as they did to boosted
