  New Posts New Posts RSS Feed - 72 TORINO HORN?
72 TORINO HORN?
SEKCOBRA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Topic: 72 TORINO HORN?
    Posted: 06-February-2024 at 10:50AM
Hi
Does anyone know if a 72 Torino came factory with one or two horns? I would think two but mine has one and I dont see where a second would have mounted.
Thanks
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
94 MUSTANG 5.0 LX NOTCH
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
64 Galaxie country sedan
1972 GTS Q CODE
1972 GTS Q CODE BLACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 06-February-2024 at 1:09PM
the wiring would be a give-away, dual horns may have been an option?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 06-February-2024 at 1:46PM
I think I had a second horn wire, but I only had one horn actually mounted in the car when I got it, which didn't work. I ended up putting in a set of high and low horns off Amazon and use the horn wire to power a relay. Works great if you're OK with kind of the same sort of look but don't need 100% stock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2024 at 1:51PM
Mine only had one horn too. I believe you could get two horns as an option, but I'd have to dig into the parts manual to be sure.  That said when my original horn died, I swapped in dual horns I had in my parts collection for an old junk yard run.  The dual horns mount in the same spot as the single.  They both have an 'L' bracket, and fit together to use the one mounting hole. The L bracket stack on top of each other facing the opposite directions so they can use the same mounting hole. My horns had a harness with it that plugs into the original horn connector and split it into two.  So it literally require no modifications.  It sounds better than the old single tone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2024 at 12:09AM
Ok. Thanks guys. I have put two aftermarket in for now. I’ll find two originals somewhere
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2024 at 11:39AM
High and low tone for the duals. On a single I would guess it is a low tone but it is a coin flip. My first 72 sport had two and occasionally I had to hit one or the other to fix it. In 1981 I wouldn't have paid for a Marti as gas was $.76/gal and bagging groceries was not filling my wallet. It had rear defrost so it was well optioned.
This page was generated in 0.134 seconds.
