  New Posts New Posts RSS Feed - 72-73 Montego hood fit on a 77-79?
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Topic: 72-73 Montego hood fit on a 77-79?
    Posted: 10-March-2016 at 6:43AM
Can't remember if this has been discussed.  Specifically, does anyone know if a '73 Montego hood will fit on a '77-'79 Mercury Cougar?  I know it will fit a '74-'76 Cougar and possibly Elite.  But not sure about the lines of the header panel of the 77-79.  Pretty sure the header panel/hood on the 77-79 T-birds, Rancheros, and LTD IIs are all the same as the 77-79 Cougar, so they should all apply.
Jeff
72 base Torino (modified)
72 Gran Torino Squire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 10-March-2016 at 10:55AM
Montego hood will fit Thunderbird/Ranchero 77-79. the peak on the center is slightly different (Montego peak runs into the header, thunderbird doesn't have this).
Elite and LTD II share the same hood (visually identical on outside and bolt up the same, same motor manual interchange #, although someone said there are differences in the underhood brace locations).
I would check with Dan the Ranchero Man, as his Monchero has a montego GT on a 77-79 Ranchero, and he is the one who told me about the Montego GT hood fitting in place of the T-bird/Ranchero hood. (Someday I WILL find one!!!)
This page was generated in 0.055 seconds.
