  New Posts New Posts RSS Feed - 73 GTSS Starting Problem
hamilton7711 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Topic: 73 GTSS Starting Problem
    Posted: 02-October-2025 at 10:09AM
Have a 351-4v. When it sits it just will not crank right up. It takes about 4-6 trys. Then all of sudden here she goes. Turn off the engine and she fires right up. It's just when the car sits for several days it is not very responsiveCry. Any ideas on this, thanks.
Joe Hamilton
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 02-October-2025 at 11:30AM
what carb?
open element air cleaner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2025 at 12:31AM
Motorcraft 4300 closed
Booyah45828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Booyah45828 Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2025 at 2:00AM
Won't crank or won't fire? Won't crank is a battery, solenoid/switch, or starter problem.
Not firing would be fuel or ignition related.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2025 at 2:46AM
Not firing correctly. Thinking the fuel bowl is not filling fast enough?
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2025 at 9:10AM
So, you are saying cold after some time (days), its a long crank to start. Is this correct?
If so, you should be looking at:
1. What is your cold start procedure? For instance, my car after a couple of days requires at least a half pump prior to crank to a. Prime (accelerator pump squirt) and b. set the choke.
2. Is the choke not setting?
3. If you are not giving it a shot at cold start it will take longer to fire over. (Unlike modern cars with fuel injection which handles the choke and prime via the computer).
From an ignition perspective...
Since it runs and starts fine after its been run, I would think the above. Timing may influence it a little, but I don't think much. Maybe a bad coil taking a little longer or alt voltage to charge up properly?
78FordLtd2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 78FordLtd2 Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2025 at 11:25AM
Your hard starting issue sounds to me that the float bowl somehow empties, either by evaporation or draining out of the carb either back towards the tank or dripping into the intake.
Try this. Let the car sit for a couple of days, fill the bowl through the vent stacks (a clean squirtable ketchup bottle works great) and then see how it starts. If it starts normally, then you know to look at the carburetor. It might need a rebuild.
Those 4300 carbs were not the greatest carbs, unfortunately.
bdaugette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdaugette Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2025 at 12:09AM
I have the same issue with my Edelbrock carb on my Cleveland.  Very frustrating, I hadn’t thought about checking the spark from the cold start, I can do that this weekend.  If not, possibly a check valve on the fuel line?
Bill Daugette
72 GTS 351C 4V
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2025 at 2:55AM
the Edelbrock carbs are notorious for evaporating the float bowls especially with an open element air cleaner, i'll be surprised if you find anything amiss with your cranking spark but it's a good check to cross off the list. i doubt a fuel line check valve will have any effect
