  New Posts New Posts RSS Feed - ’73 Mercury radio 8 tracks
73MontegoSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73MontegoSW Quote  Post ReplyReply Direct Link To This Post Topic: ’73 Mercury radio 8 tracks
    Posted: 05-February-2004 at 7:47PM
Hello,
I have one question .Is there an AM/FM radio 8 track option for ’73 Montego?I saw in the list of ’73 Montego options on your site that there was AM/FM stereo,but was it 8 track,too?I have ’73 Montego MX wagon(with 351C and FMX) and I would like to put the original ’73 Mercury 8 track(mine is missing the radio),but I don’t know if the faceplate is the same.Radios and radios with 8 track player are the same for ’73 full size Mercury and for Montego,right?
   Thank you very much.
Regards,
Boris
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 05-February-2004 at 8:17PM
I can not find where an 8T was available on 73 Torino or Montego. It does show up in 74:
AM FM Stereo w/ 8 Track         $363.20
So if the radio will fit in there, use it (sometimes there are differences between full-size and mid-size components). If you are going for a factory appearance that is correct, find an AM/FM Stereo. They were more or less identical 73-76 on mid-size. I do not know what they looked like on full-size.
Hope that helps!
Torinogts73c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torinogts73c Quote  Post ReplyReply Direct Link To This Post Posted: 14-February-2004 at 6:51PM
I      I installed an 8-track from a later 76 Ford in my 73 Torino the only interference was at the top wher the button is I believe it was the eject button, I notched the dash and it worked fine. Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73MontegoSW Quote  Post ReplyReply Direct Link To This Post Posted: 16-February-2004 at 11:08PM
Thank you very much guys for the replies.
I will stick to the original options even if I would really like an 8 track,but I will look for AM/FM Stereo Radio for my '73 Montego.I don't want to make any modifications on the dash.
Regards,
Boris
