73 Ranchero GT |
Page <12 |
cjstaci ![]() New Member ![]() Joined: 07-August-2023 Location: Seattle Status: Offline Points: 22 |
You are absolutely right. it's the sector shaft diameter that's the problem.
72 RS 351 ![]() Senior Member ![]() ![]() Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 2568 |
When I changed my 72 to power steering, I might have replaced the pitman arm with the PS version. Just another odd thought, is the Mustang pitman arm much different? I used the Mustang PS box, so I'm guessing that the size of the sector shaft matches the Gran Torino also. If the pitman arm is available, how do they differ, the length or shape? I was in high school at the time, I knew nothing about cars, I probably thought any parts were the same if they looked the same. I had help from an older friend, who had a wrecked 71 Mustang. So all I remember is that I got the used steering box and PS pump from his Mustang, the lines and pitman arm I can't recall. It was straight forward except for mounting the PS pump, the rest was easy work.
Inkara1 ![]() Member ![]() ![]() Joined: 17-November-2021 Location: Ridgecrest, CA Status: Offline Points: 173 |
This listing shows an arm for 77-79 Ranchero and LTD II. It doesn't specify power or manual steering.
Same seller has a listing for a 77-79 Thunderbird arm. I'd be mighty surprised if the T-bird could be had with manual steering.
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5607 |
Good find. Pretty sure power steering was standard for Ranchero and T-Bird by 1977, so these should work. This brochure shows it as standard: |
It states 1-1/8 sector shaft. Might be easier if I change the steering gear to one with the smaller sector shaft.
The later 70's models have more common parts, easier to find. If those are all available, for this kind of obsolete part problem, swapping to the later parts is a good option. But you need to make a good build book for any vehicle that has many non stock parts, so future servicing is much easier for the next mechanic. Discovering odd parts in a vehicle is hell for a mechanic.
Are you talking about the eBay listings for the '77-79 cars above? I didn't see any listing of the sector shaft size on those ads. I did some more digging using the Master Fords Parts Catalog. From 1975 on, there were no manual steering cars. All 1977-79 cars use P/S too. There is a difference in the 1977-79 pitman arms, and maybe also the center links. Both aftermarket and Ford part numbers show a different listing for the 1977-79 cars. If Randy (Big Bird) sees this post, he might know if they swap. Rare parts shows the specs for the 1972-76 Pitman arm here: The 1977-79 Pitman Arm here: Also, D7OZ 3590-A is listed as the 1976 Pitman arm, while D7OZ 3590-B is the 1977-79 Pitman arm. Kanter got back to me, and basically said the part is obsolete, and seemed to have zero interest in helping our community.
I am not sure if you are going to try a used Pitman arm or one of the NOS parts with the updated numbers. But it looks like this Centric arm might be available here from this vendor: It appears to be in stock, but you might have to order to confirm.
Vivid Racing is one of those places places that shows things on their website they don't actually have.
I checked, they don't have it. Finding a used one in useable condition would be a longshot. It's not easy finding a used worn one. If I could find one, I could remove the balljoint, measure it and try to find a replacement. Another option would be to convert it to a rack & pinion.
My problem now is time. I am getting ready to retire, pack up and move to NM. Might be a month or two, maybe three. I am thinking I might be better off to sell this. I bought it for $4000 and put over $3000 into it so far. I got it dependable enough that I have been driving it 50 miles a day to and from work. But it's a 50 year old car that is unrestored. The engine runs great and the trans shifts great, Rear end is good, Ive replaced the axle seals and pinion seal and gear oil. It has some rust on the left rear lower quarter and a few other spots but solid floors and a straight body with original paint. If I could get my money back out of it I would sell it, otherwise I will drive it to NM and work on it later.
Hoggfiddles says he has one, it might not be overly worn and better than the one you have. Or at least you could have spare to try and rebuild. |
I sent him a pm but haven't heard back yet.
I found a used one online from a 72 Gran Torino. Hopefully it will be good enough to use. I will post an update when I receive it.
I received the pitman arm and installed it today. It is excellent. The Ranchero steers much better now.
Funny thing, I saw a new listing on Ebay yesterday for a new pitman arm. It was a buy it now price of $250. It sold quickly. Today, I noticed the same pitman arm pictures now being sold on two separate listings, one for $295 and one for $365 by the same seller. Maybe he bought it and is trying to make a buck.
Page <12 |
