  New Posts New Posts RSS Feed - 73-76 Torino / Ranchero Pitman no longer available
Pat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat Quote  Post ReplyReply Direct Link To This Post Topic: 73-76 Torino / Ranchero Pitman no longer available
    Posted: 31-August-2024 at 5:31AM
Hi Torino friends,
I have an annoying problem here that needs to be solved. It will affect many of us sooner or later. The Pitman arms for the 1973 Torinos/Rancheros with power steering are no longer available anywhere. I am also not aware of any way to get them working again with a reconditioning kit or a new build. Without the Pitman arm, the vehicles will no longer be able to get on the road in the future. So the question now is how to solve the problem. Whether the Ford steering gear can be replaced with another steering gear, for example, or a Saginaw (Lares 806) in order to then use a different Pitman arm than the actual K8217 (Rareparts 20135). Can anyone say anything about this? Which alternative steering gear with a still available Pitman arm can be used, or does the replacement with a Saginaw work? What do you have to bear in mind when converting and which Pitman arm can you then use? Best wishes and thanks for your information and opinions
Pat
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2024 at 8:54AM
Rare parts can rebuild the 72-76 pitman arms. The issue is the forgings for the 72-76 pitman arms have not been made for decades. Rare parts bought up the last of the stock Moog and TRW had when they were still making just the forgings.
On the size of the taper and length, you can get ball joint reamers to match the taper, but the difference is in the pitman and idler arm lengths.
Ultimately, you could likely replace the pitman arm and idler arm for the 77-79 cars, and keep the center link, inner and outer tie rods and have a wheel alighment (assuming the tie rods are the same)
Edited by Eliteman76 - 31-August-2024 at 5:07PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2024 at 10:00AM
The 1972-76 pitman arms are out of production and it seems other than the odd NOS part, they are no longer available.
We discussed this is some detail in this thread:
The only alternative, short of rebuilding a good core, would be to try a 1977-79 pitman arm.  I am not sure why there are minor differences and don't know how these differences would effect the car.
Here is some info Inkara dug up:
Originally posted by Inkara1 Inkara1 wrote:
They're just a little bit different. Specs below from Rare Parts. Top one is for 1972 Torino, bottom is for 1979 T-bird.
As for the Saginaw swap, it is relatively straight forward.  Some of these cars came with Saginaw steering boxes from the factory.  However, they use the same pitman arm as the Ford boxes.  I swapped a Saginaw box in my car.  It required some minor mods to the coupler and a new PS hose, which is available OTC from any parts store.
Pat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2024 at 8:52PM
Thanks for your help. Unfortunately, Rare Parts requires the old Pitman to be sent. That's strange, because it's not possible to replace the old ball joint, which is what all the experts tell me. So what's the deal like here and I don't feel good about sending my super important part without knowing what will happen to it and whether it might get lost in transit. The Pitman for the 1977-1979 cars (K8256) is unfortunately no longer available either. I haven't found a source. .. So exchanging it on Saginaw doesn't seem to be a solution either, because I need the same Pitman arm here too, is that right? When I look at available steering gears (e.g. Lares), they have different diameters on the drive shaft (Ford 29, Saginaw 32mm), apart from the input shaft. So I thought that a different Pitman arm would have to be used there too. I'm really a bit desperate now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 02-September-2024 at 12:43PM
the ball socket is not user serviceable but can be replaced by a qualified rebuilder with the correct parts and equipment. send it in
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2024 at 2:09PM
Rare Parts has been rebuilding them for the Mustang restoration market for nearly 30? Years according to the phone discussion I had with Glenn.
I just found a pitman arm I saved, and I am actually going to send mind off so I have a spare.
FYI this was from an email from Rare Parts…reach out to them and call them.
I’ve been pleased with dealing with them.
On Wed, Jan 31, 2024 at 1:34 PM Glen Knowles <glen@rareparts.com> wrote:
Hello Andrew,
I just got a response back from our Manufacturing Team. They would like to see if you have a Pitman Arm for your 1972-1976 Gran Torino with Power Steering that you can send in so we can determine what components are needed in order to offer a rebuild service for this arm. Please let me know if you have a used spare.
Please let me know and I can let you know how and where to send it in.
Thank you,
GLEN KNOWLES
CUSTOMER ACCOUNT SPECIALIST
Rare Parts Inc
