79 LTD II REAR END |
79 ltd II All green
New Member Joined: 19-July-2010 Location: Michigan Status: Offline Points: 29 |
Posted: 23-January-2011 at 1:16PM |
exscuse the caps lock but i wanted to know if the rear axle in the 79 ltd II was 31 or 28 spline. if it helps its a 351m with c5 from the factory
Psquare75
Should be 28 spline unless someones been in there or altered things.
79 ltd II All green
no its never been apart but i wanna put 3.00 gears in it and get rid of the origonal 2.45 gears
GranTorinoSport
If you find the tag on the axle, we can help decode it. There should be a metal tag with a code on it that is attached to one of the bolts holding the differential in.
Webmaster |
occupant
Senior Member Joined: 23-October-2006 Location: Lawton, OK Status: Offline Points: 1973 |
You have 2.45 gears? I thought the tallest gears were 2.50...
08 Explorer EB, 195K, for the wife still looking for another something |
Psquare75
I thought it was 2.47:1
iangj
Senior Member Joined: 06-March-2009 Location: Fonthill, ON Status: Offline Points: 1019 |
I have a complete rear end from a '73 Montego GT with 3.00:1 gears available.
I could sell the thing whole or just the center section. Heavy item will cost in shipping though. I could deliver to the Columbus swap meet in April or maybe Carlisle in June. I see you are in Michigan. I'm near Niagara Falls Ontario if that helps in any way.
Ian Glyn-Jones
Fonthill, Ontario, Canada Wish I had My Baby Back Montego GT Registry Forum; http://mmgt.forumchitchat.com/ |
Regul8r
Ian is it a posi set up?
iangj
No it's an open.
I have no use for it other than just spare parts to me. My car has 3.25 and I may go up to 3.5 but we'll see how it runs first. I'm a long way off having it done.
Ian Glyn-Jones
79 ltd II All green
it is 2.47 but i have the 3.00 set up just wanted to make sure it wasnt a 31 spline
