  New Posts New Posts RSS Feed - 9-in rear end woes
9-in rear end woes
Uncle Larry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Uncle Larry Quote  Post ReplyReply Direct Link To This Post Topic: 9-in rear end woes
    Posted: 12-July-2024 at 6:06AM
Greetings and much thank you in advance.
I've got a 73 Ranchero with a 9-in rear end and it had a bit of a howling noise that developed sounded like a set of off-road tires almost so come to find out the rear end was 3 qts low on oil. Filled it up with oil and it didn't go away but it started leaking. So I pulled the axles pulled the third member out I was going to change all the bearings in it at least the carrier bearings in the pilot bearing but none of them have any significant pitting or damage or wear patterns doesn't seem like they're needing to be replaced maybe it was just due to incorrect opinion spacing any ideas on this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2024 at 10:54AM
they say if a Model T isn't leaking oil there's no oil in it, same with your 9"
sounds like (pun intended) it needs a complete rebuild with new ring & pinion or replace the complete pig
sorry for your loss
Post Options Post Options   Thanks (0) Thanks(0)   Quote Uncle Larry Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2024 at 12:13PM
The thing is nothing looks burned or harmed in any way. I don't see any damage
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2024 at 1:34PM
could be an axle bearing or both?
did you get eyeballs on the pinion pilot bearing & journal?
won't cost anything but time & effort to put it back together with pinion depth & ring gear lash reset and see what it does
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2024 at 4:21PM
Does it make the noise always or on acceleration or deceleration only?
I ran mine low after replacing seals while awaiting the parts for a trac-lok to install at a later date. It had maybe a quarter when it started to come out of the fill hole. Stupid me just plugged it and drove the rest of the season like that. It was evidently enough to keep things wet and not kaboom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Uncle Larry Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2024 at 8:14PM
Mostly 50 mph plus on or off throttle
Post Options Post Options   Thanks (0) Thanks(0)   Quote Uncle Larry Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2024 at 8:15PM
Mostly 50 mph plus on the throttle and off
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 23-July-2024 at 4:55PM
Rebuild it and be done. Lots of videos on youtube that go through the whole process. Parts kits are available from Rock Auto. If you have 2.75/1 gears it will be a gear change unless you can find a good set used.
