  New Posts New Posts RSS Feed - Already breaking parts….
av8or55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote av8or55 Quote  Post ReplyReply Direct Link To This Post Topic: Already breaking parts….
    Posted: 27-June-2021 at 9:01AM
Started on the list of snags on my Torino.  1st task was to replace the ancient headlamps with new units.  Managed to get all four out but two of the retaining rings have had their hold-down clips snap off.
Where do you guys like to source replacement parts from.  I have found new rings here:  https://restorationpartssource.com/store/Torino_1968_1969.htm
and
Any experience with either?  From the vendors forum, most comments about “macsautoparts” are about delivery times and lost parts.
mtburger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtburger Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2021 at 4:17AM
Hello.
Very common issue over the years, and chasing new retaining rings just about every time i would change a headlight got to be a real pain.
Now I clamp them together with a needle nose vise grip, drill an 1/8th inch hole where the spot weld was and rivet them back together.
make sure the steel nail or pin is not still in the rivet, then hammer & dolly the rivet flat.
Takes about 10 minutes and you are back in business.
When I was replacing them, they were still available from Ford and in junk yards, now ebay and places like Green Sales or Stillwell Obsolete are your best bet for new ones.
Mike H.
Post Options Post Options   Thanks (0) Thanks(0)   Quote av8or55 Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2021 at 5:07AM
Thanks Mike.  Excellent tip. I’ll give it a go
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2021 at 10:40AM
i do like mike but a tiny tack weld with the mig Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote av8or55 Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2021 at 10:49AM
Good challenge for my welding practice.
I have located a yard in my area who may have some rings.  Owner suggested soldering the clips on.  Looks like I have something to do today
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2021 at 11:52AM
  Spot welders are pretty cheap. Come in handy.
This page was generated in 0.099 seconds.
