  New Posts New Posts RSS Feed - Alternator light flashes
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Topic: Alternator light flashes
    Posted: 17-September-2023 at 3:58PM
The battery is fully charged. Wires are tight. The car runs fine. Any idea why it is doing this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2023 at 4:42PM
Everything good with the voltage regulator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 19-September-2023 at 12:13PM
Measure the voltage across the battery posts and see what the alternator is putting out when the car is running.  It might be that it's borderline weak (or the voltage regulator is going bad) which is causing the light to flash.
