Alternator light flashes |
Dino ![]() Member ![]() Joined: 08-September-2023 Location: Jackson Mi Status: Offline Points: 45 |
![]() ![]() ![]() ![]() ![]() Posted: 17-September-2023 at 3:58PM |
The battery is fully charged. Wires are tight. The car runs fine. Any idea why it is doing this? |
Inkara1 ![]() Member ![]() ![]() Joined: 17-November-2021 Location: Ridgecrest, CA Status: Offline Points: 173 |
Everything good with the voltage regulator?
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5607 |
Measure the voltage across the battery posts and see what the alternator is putting out when the car is running. It might be that it's borderline weak (or the voltage regulator is going bad) which is causing the light to flash.
