  New Posts New Posts RSS Feed - Alternator light
Alternator light
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Topic: Alternator light
    Posted: 29-August-2022 at 12:44PM
I have a 76 Ranchero GT with the 351M/400 auto. Lately, the alternator light has been slowly coming on. When I start the car, everything is fine but after about 1 minute of idle, the light will very slowly start glowing. After about 3 minutes, the ALT light is at full glow. It has a new battery, alternator, voltage regulator, starter solenoid. The battery shows about 13.75v at idle, so it is being charged.
Has anyone else ever experienced this "slow glow?"
JT, USAF Ret./Architect
1971 Ford F100 "Lizzy"
1971 Cougar XR7 "Kitty"
1984 Chevy Silverado "Sylvia"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2022 at 1:57PM
Does engine RPM make a difference?
13.75V is low. It should be in the mid 14s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2022 at 12:07AM
RPMs do not make any difference to the light, I have not checked the volts at higher RPMs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2022 at 4:32AM
how did the contacts in the regulator harness plug look when you changed the regulator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2022 at 5:51AM
The contacts looked good and normal. I did use a touch of dielectric grease on the contacts.
Greg73Oregon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg73Oregon Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2022 at 7:37AM
The insulator grease may be acting like a resistor.  Not a recommended idea.
GKF
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2022 at 7:48AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg73Oregon Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2022 at 9:19AM
Without going into a lengthy discussion, you have low voltage problem.  As the other responder advised, your voltage should be 14.6V to 14.8V. (This accounts for making up for/overcoming the internal resistance of the battery.  If the battery was "perfect", it would have no internal resistance and could providing infinite current).
Unless you are clear about your relay contact material: silver, fine silver, silver alloy, silver cadmium oxide, silver tin indium oxide, silver copper nickel, nickel, etc., I'm suggesting that dry contacts are used.
In fact, some relay contacts made for higher currents are designed such that the arcing that occurs when opening & closing actually clean the contact area.
GKF
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2022 at 9:46AM
I have always wondered about what the proper amount of dielectric grease is, too much versus nothing etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2022 at 11:24AM
Just for clarification: neither the new voltage regulator nor the dielectric grease made any difference at all in the prognosis of how the car is acting. After everything that I have done and replaced, it is responding 100% the exact same as before I started touching anything. That is why I am baffled about this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2022 at 12:37PM
have you had the charging system tested in the car?
if that's not an option pull the alt off and take it in for testing
lately new parts are Censored
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2022 at 2:38PM
Load tester at Harbor Freight is like $20. Worth the try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2022 at 8:19AM
VAT-40 test free at the parts store
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2022 at 12:45AM
It seams to be a series of electrical shorts...
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2022 at 9:57AM
Okay, y'all gonna need your thinking caps on. Supposedly, there is a 15 ohms resistor located someplace on the green/red stipe wire for the charge indicator light. This resistor is what is suspect. I talked to an experienced ford technician and he stated that is why the ALT light will slowly come on. He states that once it hits 3 volts on either side of the resistor, it will slowly build up an indication, hence the light.
So, the ultimate question is now, does anyone know where this resistor is located? Could it be inside the small voltage regulator that is on the back of the instrument panel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg73Oregon Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2022 at 12:13PM
I found it on the wiring schematic, but where it is physically located, I don't know.
GKF
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2022 at 2:41PM
It looks like it might ve close to connector 482. The entire wiring diagram can be downloaded here:
I don't have time to go through it now, but I believe they usually show you what each of the connectors look like and each connector's location.
Edited by 72FordGTS - 12-September-2022 at 2:18AM
Post Options Post Options   Thanks (1) Thanks(1)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2022 at 3:42PM
UPDATE: After many, many, many trials and errors, I have found the culprit, and it was a surprise. The rebuilding of the ignition switch is the smoking gun that finally fixed it! I went through the entire electrical system of the whole car (yep, I completely went through EVERYTHING) and the ignition switch did not look kosher. I took it out and went through it, soldering loose items, cleaning and put it back in. Alternator light since has worked as designed by Ford since then!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2022 at 4:36PM
Well done, perseverance is your power.
spriegel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spriegel Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2022 at 6:45PM
That’s great news!   Thanks for sharing the root cause!
Fairview, PA
'1973 Ford Gran Torino
Hinmaton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hinmaton Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2025 at 2:17AM
Sorry to bring a post back from the dead, but I’m having very similar-ish symptoms. My alt light will slowly glow when the rpm’s are above an 1,500 rpm’s, at low idle it remains off. It never gets more than maybe 50% bright and kind of flutters on and off while I’m driving. I load tested the battery and it tested strong. I tested the charging system and it passed fine. At idle the battery reads low to mid 14’s, and it increases with more rpms.
Admittedly, I have not checked my ignition switch yet. But my tachometer (added on) has recently been randomly swinging and when I’m below 1,200 rpm it just falls to zero.
Both of these symptoms are new and but did not start happening at the same time, nor do they appear to be directly tied together. The tach seems to function best at higher rpms, while the ALT light indicates with higher rpms.
It’s a 71 Torino 500 with a 5.0 roller motor, factory ac, power brakes and power steering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2025 at 11:58AM
are you aware there's an Instrument Panel Voltage Regulator ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hinmaton Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2025 at 2:57PM
I suppose I did not. Is this something that can be tested or just replace and see?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2025 at 4:05PM
i'd do a little more diagnosis before firing the parts cannon, you say the ALT light comes on stronger at higher rpm? what is the battery voltage when the light is on?
low to mid 14's sounds fine but it should not increase with rpm, i have to suspect the charging system voltage regulator is not maintaining a steady voltage, could be the source of the Alt light?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hinmaton Quote  Post ReplyReply Direct Link To This Post Posted: 23-May-2025 at 10:30AM
You are correct. The voltage stays a constant 4.2ish no matter the rpm increase.
Still think voltage regulator?
This page was generated in 0.100 seconds.
