Any 73 GTS owner add a functional 69 Torino Scoop? |
Post Reply
| Author | ||
GoldFinger
Joined: 03-April-2015 Location: North Carolina Status: Offline Points: 295 |
Quote Reply
Topic: Any 73 GTS owner add a functional 69 Torino Scoop?Posted: 18-October-2015 at 5:18AM |
I have a 69 Torino scoop with the turn signal indicators in the back of it that we will be putting on my 73 GTS hood in a few days..
I thought about cutting a hole in the hood to make it functional.. I was wondering if anyone has actually done this? Any advice would be appreciated! THANKS!
Quote Reply
Posted: 18-October-2015 at 6:56AM |
I can tell you from the experience of running a 72 sport hood with open scoops that your engine compartment will take on the look of a car that's been sitting in the scrap yard if you don't fab up a seal & drain similar to a factory shaker or ram air
dave302
Joined: 08-October-2009 Location: usa Status: Offline Points: 3171 |
Quote Reply
Yes there is someone who has done it, but he had cut a larger/wider hole in the hood and he installed a wider hood scoop onto the hood. I believe that the hood scoop that he had installed was from a 1993 mustang. There is a picture of the hood below.
dave302
Quote Reply
Posted: 18-October-2015 at 6:59AM |
There is a picture below of the hood scoop installed.
![]() Edited by dave302 - 18-October-2015 at 7:13AM |
GoldFinger
Quote Reply
Posted: 18-October-2015 at 7:29AM |
Thanks Guys so far!
I am going to get the rubber flapper piece.
Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14723 |
Quote Reply
Posted: 18-October-2015 at 10:46AM |
that's a scoop from a mid 80's mustang.
just depends on if you plan on driving it a lot in the rain, or not |
GoldFinger
Quote Reply
Posted: 18-October-2015 at 12:40PM |
No I won't be driving in the rain intentionally.
GoldFinger
Quote Reply
Posted: 18-October-2015 at 12:44PM |
I already have the 69 scoop.
lynchster
Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 2150 |
Quote Reply
Posted: 18-October-2015 at 3:58PM |
Cut a piece of foam that you can wedge in the inlet. It will have to be tight enough to stay put but not so tight to crack the scoop.
Skinnys Garage
Joined: 26-February-2010 Location: South Dakota Status: Offline Points: 277 |
Quote Reply
Posted: 18-October-2015 at 4:25PM |
I ran one of those on my '73 for a while before switching to an Eliminator/Comet GT scoop. The '69 scoop will need some messaging at the rear to fit the center hood peak. Also will need to cut some holes for the turn signal housings to fit through (they hang below the scoop a bit). I ran mine without a hole for a while, then cut one to fit a velocity stack through. If you decide to make it functional, some of the hood brace needs to be cut out also. Currently in the process of finishing up my '72 scoop conversion (Frankenscoop). Good luck with your project. Scott
Scott -'73 Gran Torino Brougham
Past Torino's -'73 Q-code GTS, '76 Original PS-122 S&H, '73 H-code GTS, '73 Ranchero '71 Cobra 351 Auto, '70 351C Brougham 2dr HT, '71 351C Ranchero |
GoldFinger
Quote Reply
Posted: 20-October-2015 at 2:18PM |
If I get the rubber flapper,why would I need foam? Most of these scoops that were on the 69 Torino's and Mustangs were not functional and they did not crack..Am I missing something? |
GoldFinger
Quote Reply
Posted: 20-October-2015 at 2:19PM |
GoldFinger
Quote Reply
Posted: 22-October-2015 at 1:17PM |
Thanks Scott! The shop has made the cutouts for the turn signals and the studs.The have also dremmeled down the back of the scoop and below the scoop becuase the back would not sit flush with the hood...The scoop looks GREAT! I decided not to cut a hole for the air cleaner...but may change my mind some time a little later on. The shop is now working on the harness to wire in the turn signal indicators on the back of the scoop. |
Post Reply
| Tweet |
