  New Posts New Posts RSS Feed - Any tip on how to Adj Driver side window
jglover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jglover Quote  Post ReplyReply Direct Link To This Post Topic: Any tip on how to Adj Driver side window
    Posted: 01-January-2026 at 8:21AM
Just replaced the window seal in my 72.  Now the gap are worse then before I changed them!  Trying to adj the glass but wish to make sure there aren't and "tricks of the trade"..  Got it a little better but still have gap at the top corner back of the glass.
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 02-January-2026 at 2:46AM
Have you tried lowering the front corner of the window?  If you lower that you might be able to raise the back corner a little more.  Also if a brand new seal I know that mine was not exactly factory correct and had some bulging in areas where the original didn't and getting a perfect seal was not possible.
Dave - 1973 GTS N code
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-January-2026 at 10:48PM
 there are adjustments for the up stops front and rear and adjustments on the plastic guides on the center pole that allow for tilt in and out and the bolts on the ends of the pole allow for some front to rear glass adjustments
also make sure your hinge bushings are good or that can cause sealing issues at the roof seal... also the striker post bushing tooWink
