  New Posts New Posts RSS Feed - Bigger tires are on! And rub...
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Topic: Bigger tires are on! And rub...
    Posted: 18-September-2023 at 9:47AM
I didn't think they would, but I want that S&H rake anyway so time to go through the coil thread again. I looked for those insulators last week and couldn't find them. Does anyone still make them?
Before: 245/60r15. After: 275/60r15 (rear only). Rubs on the driver side. Probably rubs on the passenger side if the seat is occupied. 2, I think, different S&H cars with the stance I'm after.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2023 at 10:27AM
I like those wheels and tires.
I think you need to change the ride height of both ends. To me the rear is too low, and the front is too high. But they are both close, I'd aim for raising the rear by maybe an inch, and the front lower by nearly the same. It's hard to adjust the height exactly to what you want it, go slow planning how much to change the springs, what coil length to cut or change.
That S&H car looks just right in the front, but I'd prefer the rear down some, just a little, maybe 1/2" at most.
I have the same 275/60 tires for the back of mine too, I chose 255/60/15's for the front. Keep at it.
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2023 at 10:30AM
Thanks! I agree with you. I will start with the rear as raising it may lower the front some. I found this one that I really like. I took a screenshot. What springs and shocks do you have to prevent rubbing? Got pics?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2023 at 10:58AM
There have been two other members here in the last year that installed 275/60/15's in the back, they looked good too. I haven't got my tires mounted yet, I had a nine month wait for the Magnum 500 replica's to be made. That's on my list to do near future. My 72 has the prior owner's choices, a 225/70/14 in front I think, and a 255/70/15 in back, all too narrow and tall profile for my taste.
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2023 at 2:32AM
I agree, not a fan of those tires. And these big wheel wells need lots of meat.
paj1965 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paj1965 Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2023 at 3:21AM
Wheels and tires are 245 60-14's front and 295 50-15's out back.  They fit great - plenty of room, no rubbing.
My Toy List:
1972.5 Gran Torino Sport
2001 Mustang Cobra Vert
2001 Lightning
2013 Jeep Wrangler
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2023 at 3:25AM
Yeah the 295/50 is 1.4" shorter than the 275/60. I ordered the wagon springs, and some spacers in case I need them. I should have it back on the road by Saturday and will post pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2023 at 3:42AM
The 275/60/15 is about an inch taller than a 295/50/15. The 275 section width adds an inch, but the 50 series loses 2" of height(1" per 5% series change).
AUS GTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUS GTS Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2023 at 12:21PM
Anyone reading this info, dont forget wheel width & off-set play a huge part.... not just tire size!
Hope those springs work out! Thumbs Up
Al
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2023 at 12:38PM
Thanks!
I got new rear shocks as well. They are shock/coil combos. I hope they are a good match for the coils but it may be a bit much. We'll see! Everything arrived today. I also have a Lares steering gear and new lines.and rag joint ro install.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 22-September-2023 at 12:03PM
Originally posted by Dino Dino wrote:
Thanks!
Look into taller springs so the upper shock mount is not carrying the load.
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Posted: 22-September-2023 at 12:26PM
Taller than the wagon 803 coils?
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2023 at 7:03AM
I installed the new shocks and coil springs yesterday and I like it! Even with our crappy roads, it rides pretty damn good. I’ll post the details in the coil spring thread as well.
Coil springs: Mevotech SMS803V
Coil spring spacer: 1” McBay Performance MP1615, 1 per side
Shock and coil spring combo: Monroe 58568
Tires front: 245/60r15
Tires rear: 275/60r15
Wheels: 15x8 American Racing Torq Thrust II, rears with 1” spacer
Before and after
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2023 at 4:33PM
Looks much better!
