  New Posts New Posts RSS Feed - Body reinforcement for rotisserie
Lizer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lizer Quote  Post ReplyReply Direct Link To This Post Topic: Body reinforcement for rotisserie
    Posted: 22-March-2021 at 4:46PM
I'm going to put the body of my 78 LTDII on a rotisserie. Do I need any kind of supports or reinforcements inside the car, or is it solid as is? I'd prefer to not have to if it's overkill or not needed as I will be painting inside as well. But I don't want the car to buckle either.
67 Mustang (5.0)
69 Mach 1 428 SCJ Drag Pack
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2021 at 2:21AM
I am not sure if anyone on here has put a 72-79 body on a rotisserie.  CaliforniaJohnny might know if reinforcement would be needed or not?  He's one of our most experience restoration guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lizer Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2021 at 5:29AM
I think it could really apply to ANY non-unibody body.
67 Mustang (5.0)
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2021 at 6:15AM
This is a pic of my body on a rotisserie that my body guy used, I don't remember him using any reinforcements.  It's not setting on the lift, we were just moving it there to put it back on the frame.
Dave - 1973 GTS N code
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2021 at 6:38AM
depends on what you need to do... if you're cutting out the whole floor, just keep the roof and quarters intact for rigidityWink if doing a roof skin keep the side structure and tranny tunnel/floor/rockers in tactWink... i think you get the idea
 if you're just doing patches and primering/painting it will be fine on a rotisserieThumbs Up
we are doing a unibody 68 camero at work now on a rotisserie so we are replacing the full quarters first then after they are all welded in then we are cutting the full floor pan out and replacing it  to keep the structural rigidity intact....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2021 at 8:53AM
It does seem like one of the members had a problem with his roof buckling a little when he had it on a rotisserie, don't remember which one it was though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lizer Quote  Post ReplyReply Direct Link To This Post Posted: 16-April-2021 at 12:40PM
I remember reading about that roof buckling, which is why I was asking.
In my case I just want to flip it on its side to paint the bottom. All the metal replacement in the floors (which is all there was) is done.
67 Mustang (5.0)
