Brake lights |
Post Reply
| Author | |
Jack hardy
Joined: 25-December-2023 Location: PA Status: Offline Points: 2 |
Quote Reply
Topic: Brake lightsPosted: 06-March-2024 at 9:00AM |
Have a 73 gts, when i bought it, signals, hazards and brake lights didn't work. I replaced turn signal switch, now I have signal, but no brake or hazard lights. When I apply the brake pedal, I have power to the turn signal switch. Pulled out drivers seat, wires all look good. I'm stumped and looking for ideas. I did try another switch in case I got a bad switch.
Inkara1
Joined: 17-November-2021 Location: Ridgecrest, CA Status: Offline Points: 515 |
Quote Reply
Posted: 06-March-2024 at 9:04AM |
The brakes and hazards aren't on the same fuse as the turn signals, so that might be something to check.
Wayner315
Joined: 19-October-2021 Location: Alberta Status: Offline Points: 225 |
Quote Reply
Posted: 06-March-2024 at 11:38AM |
Maybe a long shot, but I chased a similar issue for hours. Turned out to be a broken terminal on the back side of the fuse block. So maybe check the backside make sure the block itself is intact and connections are clean and good.
Wayner315
Quote Reply
Posted: 06-March-2024 at 11:40AM |
Sorry, technically i meant it was a broken spade connector, connecting to the block.
Joel & Becker Wilson
Joined: 25-June-2020 Location: Charleston SC Status: Offline Points: 31 |
Quote Reply
Posted: 10-March-2024 at 2:03PM |
Forgive me, but I will piggy back your question as I have just today discovered something similar with my 72 GTS.
I have just pulled 2 sockets out of each of my rear light assemblies. each housing: 3 wire socket and middle 2 wire socket. Reverse socket is intact on both housings. (I can share the sockets that I found that clip into the housing if anyone is interested.) As I connected each socket back to the original wires they seemed to work. The driver side did blink oddly as the 3 wire bulb and the 2 wire bulb alternated. When I connected the passenger side housing, i noticed that when I pushed the brake pedal, the driver side lit up but I lost the running lights in the passenger housing and did not get the brake light in that housing. I also noted that the running lights are dim. One other note: the passenger side blinking works as I remember. both bulbs flashing bright to dim, not alternating as the driver is doing. Maybe there is an answer out there for both of us... |
Joel and Becker Wilson
72 GTS 351 Cleveland 2v |
Post Reply
| Tweet |
