Bucket seat conversion |
yellowsportwagon
Member Joined: 25-August-2015 Location: illinois Status: Offline Points: 193 |
Posted: 01-April-2017 at 3:23PM |
Who has done a bench to bucket conversion?i need some answers concerning shifter wiring.
Tim |
you mean more like column to floor shift conversion???
yellowsportwagon
Yeah that one.
well from what i understand... there is a short wiring harness that connects the shifter wires to the NSS at the bottom of the column, or you can test wires and connect them yourself. my floor shifter had the wires cut off and the NSS was broken i used an AOD tranny so the NSS was inside the tranny so i just hard wired them into the wires from my old column
yellowsportwagon
I think I have that harness and I have the floor shift column.i guess I need to know if the rest of the wiring under the dash is the same.
Tim |
should be?
changinlatitudes
Senior Member Joined: 14-April-2013 Location: Union, MO Status: Offline Points: 554 |
Sorry Tim, I really shoulda done a better job taking that harness apart. I'm sure these guys will know what goes where.
Matt
1969 Mercury Marauder 390 1972 Montego MX 2003 Mercury Marauder 300A 1994 F-150 5.8 2016 Ford Fusion Titanium |
yellowsportwagon
That's ok Matt I'm just making sure I have everything I need before I make a mess of this thing.
Eliteman76
On the floor wiring harness, doesn't matter column or floor shifter, the harness has a wire looped that will interrupt the starting circuit. On a floor shift car that wire is plugged into the harness and ties to neutral safety switch.
On a 4 speed car, that wire is merely looped as our cars don't have a neutral safety clutch switch to prevent bump starts with the car in gear. Under dash won't matter, it's all in the floor harness. I'm sorry but I don't have any pictures for you to be able to reference at this time. |
Pondering: #99Problems |
