c4 automatic transmission |
benzesrule
Member Joined: 21-November-2010 Location: Kenton, Ohio Status: Offline Points: 106 |
Posted: 23-November-2010 at 11:22AM |
I have a 1973 Torino with a 351w and a c4 transmission. The transmission goes into reverse perfectly but when shifted into drive it does nothing. Any suggestions?
Phil
ilyes
time for a full flush, if it doesn't help, you're good to drop the pan and check the valve body
you could read a bit and/or search here,
or get a manual with a diagnostic troubleshooting checklist and go from there
does it do anything if you pull it down manually into L2 or L1?
does it catch Drive it you let the engine warm up a while?
i doubt there's anything you can do in the pan or valvebody since it does have Reverse, if you tear into and make a mess of it, it'll just make it harder for the trans builder to figure out what's wrong
Ranchero72
Member Joined: 08-June-2009 Location: Central IL Status: Offline Points: 184 |
Had this issue with my C4. Low fluid level was the cause.
'72 Ford Ranchero 500
-351C C4 |
benzesrule
Thanks for the replies! It does nothing when shifting it into drive or any other forward gear. It shifts really smooth into reverse. I haven't let the car warm up because of the old gas in the tank. I will be cleaning the tank next week. The car only has 76037 miles on it. Thanks
Phil
sometimes miracles happen with a filter & fluid, but it has enough fluid to get Reverse...
old units get what they call 'morning sickness'
the seals dry up, harden and don't seal until they warm up & soften a little. in those cases maybe a 'conditioner' product would restore / improve function
if it has sat a while maybe a piston is stuck, could be a valve in the body stuck too
73 GT Sport 429
Senior Member Joined: 25-October-2010 Location: TarponSpringsFL Status: Offline Points: 277 |
How's your fluid level? |
Mark
original owner-93 Lightning 73 Gran Torino Sport 429 (prodigal son) |
benzesrule
update...When the rear wheels are off the ground the trans will go into gear and even feels like it shifts. When the car is cold, it moves in forward. any ideas?
Phil
i would hope a guy checked & corrected the fluid level before posting a trans related Q?
fluid is properly checked warm & after running the selector through the ranges several times to fill the converter & valve body. if checked cold the level may show a little under FULL but should still be run through the ranges
iangj
Senior Member Joined: 06-March-2009 Location: Fonthill, ON Status: Offline Points: 1019 |
I had this issue with my '73 Montego way back.
Sheared the teeth off the forward clutch hub. Had to drive it 20 miles backwards to get home.
Ian Glyn-Jones
Fonthill, Ontario, Canada Wish I had My Baby Back Montego GT Registry Forum; http://mmgt.forumchitchat.com/ |
