  New Posts New Posts RSS Feed - C4 Trans will not shift to 3rd
r9b2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote r9b2 Quote  Post ReplyReply Direct Link To This Post Topic: C4 Trans will not shift to 3rd
    Posted: 29-April-2024 at 12:45PM
Hey all, recently rebuilt my C4 transmission using a B&M shift kit and a rebuilt kit. Car does not have 3rd gear -- Reverse works fine, shifts from 1st to 2nd fine, and then when trying to shift from 2nd to 3rd, there is what seems to be major slipping. The car still drives forward but not any more than 20-25 mph without winding the engine up.
At first, noticed that I accidentally left the vacuum modulator hose disconnected from the manifold, so attached that, and nothing. Then, pulled the valve body off to check that and everything seemed fine. When I pulled the valve body and in the pan was a decent amount of very fine metallic shavings. Today, we tried adjusting the intermediate band (1 and 3/4 turns out) and nothing, then swapped vacuum modulators, still nothing. The last thing attempted was that, according to internet advice on a Bronco forum, the throttle modulator valve (also called a spool, I guess) could have been backwards. Swapped out the pin to the B&M-supplied gold pin and reversed the throttle modulator valve and now the car is burning transmission fluid, which wasn't happening before.
Ran out of time before I had to call it a day, so seeing if any of you have any advice. I have no clue what could be causing it to have barely any shift into third gear. It did manage to shift into 3rd a couple of times, but it's not consistent at all. Thanks in advance for any help!
1975 Ford F150 300I6 4spd 4x4 Project
1973 Ford F100 429
1966 Ford Mustang I6
2025 Subaru Forester
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 30-April-2024 at 7:41AM
I can't help you with your problem, but if no one here can help you diagnose, try the Ford Transmission forum.  A few experts post on there, but sometimes the response time is slow (it's not very active).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 30-April-2024 at 11:34AM
Double A, M, C, O
All
Automatics
Must
Come
Out
you did the rebuild yourself?
"a decent amount of very fine metallic shavings"
that's bad
r9b2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote r9b2 Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2024 at 2:13AM
Thanks guys, I’ll try a cross post to another forum too. Did a pressure test and both modulators were bad, so ordering a TCI modulator. At this rate I’d just want to do a manual swap lol
1973 Ford F100 429
