  New Posts New Posts RSS Feed - C6 floor shifter seal
JBR-3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBR-3 Quote  Post ReplyReply Direct Link To This Post Topic: C6 floor shifter seal
    Posted: 22-September-2025 at 11:11AM
I copied these two pictures from a post written by member TV 2M8O, I hope this is not out of line.
These are the only two pictures I found anywhere of this seal. This seal is the part I'm inquiring about.
I believe it goes under the shifter hump but on the tranny tunnel floor, it would seal the shifter
housing from the outside world under the tunnel.
Anyone know if these are reproduced ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2025 at 8:52AM
The master parts catalog show that is part:
D1zz 7c360-A
It is shared with the 1971 - 73 Mustangs and the Mavericks of the same era.
I quick search did not find that it is reproduced, but let us know if you find one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBR-3 Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2025 at 11:03AM
 Thank you ! Mine is battered but usable I suppose.
