  New Posts New Posts RSS Feed - c-6 shift shaft
c-6 shift shaft
jrocket View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrocket Quote  Post ReplyReply Direct Link To This Post Topic: c-6 shift shaft
    Posted: 21-October-2023 at 6:29AM
I will be installing a 428-c6 in my 69 this winter, wondering i anyone has the part number or even a pic of the correct shift shaft for a column shift car?
the shaft in the c-6 I mean.
thanks!!
mdhracing View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdhracing Quote  Post ReplyReply Direct Link To This Post Posted: 02-April-2024 at 2:05PM
message me, and i can show you what you need. I have a 69 Talladega, with the set up. I had to source some parts, and had to make some.
mdhracing@aol.com
CMC CHIEF MIKE
Rosedalenative View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rosedalenative Quote  Post ReplyReply Direct Link To This Post Posted: 08-October-2024 at 11:54AM
I have a Talladega, trying to replace a leaky oil pan gasket.   I know the engine has to be raised a few inches.    I removed the 8 bolts holding the two side motor mounts to the frame.  I also removed the big nut in the middle of each.    Engine doesn’t move.   What am I missing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdhracing Quote  Post ReplyReply Direct Link To This Post Posted: 10-October-2024 at 2:47PM
Did you remove the motor mounts completely?
If so, you will probably need to take the transmission mount loose. Make sure nothing on the top is in the way. Make sure the fan blade is not hitting the shroud. The oil filter is real close to the sway bar.
The exhaust, depending on what kind you have, can hold the engine also. Be careful not to bend the transmission linkage.
CMC CHIEF MIKE
This page was generated in 0.124 seconds.
