  New Posts New Posts RSS Feed - Carlisle Ford Nats Show
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Topic: Carlisle Ford Nats Show
    Posted: 16-May-2022 at 8:39PM
I will be running out this year with my Superduty and trailering the GTS for the Ford Nationals show this year.
With that said I still have odds and ends. I do have my '72 small bearing 9" I just pulled from my GTS.
Pretty sure the passenger side axle is tweaked, or it needs new seals because I accidentally overfilled the axle on the last rebuild.
I was looking to pull the pumpkin out, and rebuild the 2.75 gear set with my 3.10 set and traclok carrier but let me know.
I have a couple intermittent wiper modules left for Torino, etc.
I also have a 73-79 F series intermittent wiper delay setup.
I have my factory maximum handling competition suspension rear upper "Diamond" control arms, along with the lower arms if someone is looking for them.
I have a couple sets of tail lights 72-73.
Found a couple trunk flippers but they are honestly mediocre at best as they are usable for parts due to damaged bases.
I also have two sets of Flowtech Headers {Holley brand, imported} that are for a 351 Cleveland 4V. Meant for automatics. Not tried fitting with a toploader/tremec yet.
12118FLT is the standard black paint set.
32118FLT is the ceramic coated set.
Both are decent quality. Nice looking sets.
Not specifically looking to drag a dozen totes worth of stuff with but if something comes up, let me know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 24-May-2022 at 3:51PM
Stupid stuff
Front seat belt receivers wheat leaf pattern
Rear exhaust hanger
Quarter glass window cranks. Short
18" air cleaner base. Snorkel unecessary
72 horn button insert. At least a base with both pins.
    I have a non 72 insert for now.
08 Taurus (Maytag)
03 Dakota (Rusty)
Elauren77 View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elauren77 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2022 at 8:17AM
Hello, do you still have the rear control arms for sale? And do you know if they take the same (hard to find) bushings as standard.
Edited by Elauren77 - 21-November-2022 at 8:23AM
bigcountry01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry01 Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2023 at 5:04PM
How much for the tail lights
brian hungler
