Castrol GTX Classic 20W50 high zinc oil? |
Inkara1 ![]() Member ![]() ![]() Joined: 17-November-2021 Location: Ridgecrest, CA Status: Offline Points: 105 |
![]() ![]() ![]() ![]() ![]() Posted: 04-October-2022 at 5:33AM |
My local Walmart now carries Castrol GTX Classic oil that advertises high zinc content (1,400 ppm max). It's available in quart bottles or a 5-quart jug for about $25. Only thing is it only comes in 20W50. Any thoughts on using that weight? The same Walmart carries Motorcraft diesel oil in 10W30 and 10W40 weights. An analysis I found online for the 10W30 says 1,206 ppm of zinc. Thoughts?
Car variables to help with decision: I live in the high desert of California to give an idea of the weather conditions. The engine is a 1972 351C that started as 2V but had the intake swapped to 4V. It has 91K miles, but I don't know the rebuild history if any. I did find a lot of pieces of valve stem seals when I pulled the valve covers. It went through 1.5-2 quarts of oil in a ~250-mile trip, but I don't know how much of that leaked out, how much went through the valve guides, how much if any went past the rings, etc. I don't know what my oil pressure is other than it's enough to turn off the idiot light.
72 RS 351 ![]() Senior Member ![]() ![]() Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 2348 |
Finding a suitable old type of oil with the proper amount of zinc etc, for the flat tappet cams and lifters is difficult, and likely they are going away more as time passes. I plan to use a full top brand synthetic, with an additive for my one flat tappet cam 351C. That would be the easiest source for good oil, and keep the cam and lifters healthy. Changing to a roller cam and lifters will eliminate the need for any special old type oils.
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5325 |
That's a lot of oil consumption. It might be worthwhile to put a mechanical oil pressure gauge on the engine to see where it is at. 20W50 is way thicker than what these engines should use if healthy. If you want higher zinc for a flat tappet cam, Shell Rotella is a good alternative. You can get it in 10W30 or 15W40. I would think in CA climate and with your oil consumption the 15W40 might be the better option.
aquartlow ![]() Senior Member ![]() Joined: 19-December-2011 Location: Summerfield, Fl Status: Offline Points: 2209 |
Another "good" alternative for higher zinc content is: Valvoline VR1 Racing 20W-50 Conventional Motor Oil 1 QT - Walmart.com
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 5799 |
look for Lucas Hot Rod & Classic
https://lucasoil.com/products/hot-rods-classic-cars/hot-rod-classic-car-10w-30-motor-oil |
